5 speed vs 6 speed PSD - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 10-17-2012, 01:01 AM Thread Starter
Talking 5 speed vs 6 speed PSD
Question about the difference between the 5 speed and the 6 speed F250's, specifically the 2000 year. I heard the 6 speed is the same as a 5 speed but it just has a granny gear with it. What dya'll know about this? I'm lookin to buy a PSD and from my research the 2000 F250 is the best, and I figure I'd get a 6 speed to help with mileage. Any input is much appreciated!!
LTbrassballs is offline
post #2 of 19 (permalink) Old 10-19-2012, 04:46 PM Thread Starter
Re: 5 speed vs 6 speed PSD
No one knows????
post #3 of 19 (permalink) Old 10-19-2012, 05:08 PM
wrenchturner250's Avatar
I didn't know they made the sd's in a 5spd........ But the 6spd has shown to be better than the 5spd in the obs. The overall gear ratio is close to the same. The 6spd has a better split between gears.
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #4 of 19 (permalink) Old 10-19-2012, 05:18 PM
I'm fairly certain the SD's only came with the ZF6
2000 F250 7.3 PSD ZF6 4x4.
CTFFEMT is offline
post #5 of 19 (permalink) Old 10-19-2012, 06:27 PM
92f350cc's Avatar
early 99 SD's came with a 5-speed IIRC.
Current Rig:
1992 F350 Custom CCLB 4x4, 5.8 V8, 5-spd.
Previous Rig:
1986 F250 XL RCLB 4x4, 6.9, 4-spd.
The Daily Driver: 1992 Lexus LS400, 4.0 V8, 4-spd auto. She's soft, smooth, and fast, but she's a real b****.
92f350cc is offline
post #6 of 19 (permalink) Old 10-19-2012, 09:59 PM
alleged moderator
tjctransport's Avatar
stock manual trans in the 99 superduty was a 5 speed. 6 speed was an option.
tom
tjctransport is offline
post #7 of 19 (permalink) Old 10-20-2012, 12:59 AM Thread Starter
Do you know if the final gear (5th for 5 speed and 6th for six speed) ratio is about the same?
post #8 of 19 (permalink) Old 10-20-2012, 04:13 AM
92f350cc's Avatar
IIRC, they are the same.
Current Rig:
Previous Rig:
92f350cc is offline
post #9 of 19 (permalink) Old 10-20-2012, 04:14 AM
92f350cc's Avatar
ZF-5 5.72 2.94 1.61 1.00 0.76
ZF-6 5.79 3.30 2.10 1.31 1.00 0.72
I don't know if the ZF-5 referenced is a S42 or S47. But the ZF-6 appears to be lower geared before you hit direct. OD is higher.
Current Rig:
Previous Rig:
92f350cc is offline
post #10 of 19 (permalink) Old 10-20-2012, 01:42 PM
Those gear ratio's are for the newer 96' up s47 tranny.. I have owned both, the s47 will launch a load a hell of a lot better then the s42.. I knew folks who left early style fords for dodges back in the day, because of the much better launching of the dodge.. Ofcourse the dodge boys like to say the ford's engine was the blame.. Not so!!
navistar45 is offline
Human Verification
HTML code is On
