7 pin blade style plug wiring help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-26-2010, 12:09 AM Thread Starter
jaybuller's Avatar
so i need a 7 pin blade style conector for my truck so i can plug in my new rv. all i have is the 4 pin flat style. so i bought the plug i need but dont know how to wire it all up... id didnt include instructions... well here is a pic. if some one could tell me what to hook the 3 wires too..( i know the white is ground ) but what about the other three? thanks yall/
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #2 of 9 (permalink) Old 02-26-2010, 12:31 AM
King Dingaling
TANK'S 250's Avatar
Re: 7 pin blade style plug wiring help!
This might help
Try this site
Trailer Wiring Diagrams
TANK'S 250 is offline
post #3 of 9 (permalink) Old 02-26-2010, 01:17 AM Thread Starter
jaybuller's Avatar
thank you thats exactly what i needed.
post #4 of 9 (permalink) Old 02-26-2010, 01:27 AM
King Dingaling
TANK'S 250's Avatar
no prob...glad I could help...
post #5 of 9 (permalink) Old 02-28-2010, 04:36 AM
tbolt's Avatar
If it's an RV they are different than a reg 7 blade. The plug you bought doesn't seem to have enough wires. Seems to be missing the Red aux power to power the convertor in the RV. The rest of it might work but it's nice having that one to charge the RV batt while the truck is running. Example. While hunting in the mtns @ 7000' in temps in the teens I hear some noise in the middle of the night. My buddies trailer batteries took a dump and he had no heat. He backed up his truck, plugged it in and got the furnace going. He couldn't start the gen so he had to use the truck. Just something to think about.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #6 of 9 (permalink) Old 03-01-2010, 01:05 AM Thread Starter
jaybuller's Avatar
naw, on this one the black wire goes to the convertor on the rv, and on the truck side it goes strait to the battery. i been chacin down a wiring problem. so ive been through all the wires two or three times now on the truck and the rv. i cant get the brake running lights to come on at all and the blinkers and brake lights are some how showing up on the dim side of the two way bulb.. the running light side... i think it may be a ground issue on the trailer side but still not 100% sure.
post #7 of 9 (permalink) Old 03-03-2010, 04:29 AM
tbolt's Avatar
on my fact plug the aux going to the convertor is only hot when the engine is running so as not to run down the batt in the truck while camping for days. if it's wired to your truck batt the conv is on all the time it's plugged in.
Glen
tbolt is offline
post #8 of 9 (permalink) Old 03-04-2010, 02:29 AM Thread Starter
jaybuller's Avatar
yeah, its an easy fix just unplug when you park to camp. im usally using my truck for other activities when i camp anyways like fishing or hunting.
post #9 of 9 (permalink) Old 03-04-2010, 05:07 AM
tbolt's Avatar
Just wanted to point that out. Sounds like you have got it together. My memory is so bad I would forget. I always have my arctic cat prowler to run around in so the trailer stays hooked up. I'm lazy about things like that.
Glen
tbolt is offline
Human Verification
