6.0 to 7.3 Conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 12-16-2010, 12:41 AM Thread Starter
I have a 2003 F-250 with an auto trans and a sick 6.0. I also have a 2000 7.3 with an auto trans that is wrecked with 114,000 miles on it. I want to put the 7.3 out of the 2000 into the 2003 with the 6.0. Has any body ever done this? Can you give me some direction?
Belairboy55 is offline
post #2 of 17 (permalink) Old 12-20-2010, 09:17 PM
Re: 6.0 to 7.3 Conversion
oh i'm sure its been done......just use all the wiring from 7.3 truck.
2008 F350 Lariat 6speed!
85yota350 is offline
post #3 of 17 (permalink) Old 12-30-2010, 05:23 AM
WINNING
Countryboy07's Avatar
You'd be better off swapping in a cummins..... The 7.3L uses an entirely different harness and you'll have a lot of fun trying to graft the two together. Just my $.02
-French
2002 VW Jetta TDI
Countryboy07 is offline
post #4 of 17 (permalink) Old 12-30-2010, 05:58 AM
stroked99_1/2's Avatar
It would be a pain... Unless you have all the wiring harness's from the 7.3, be plug and play then, swap it all over, piece of cake and go.
Renegade Diesel
stroked99_1/2 is offline
post #5 of 17 (permalink) Old 02-18-2011, 05:06 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
I've got a guy wanting me to do a similar conversion. He has his '99 7.3L 6 speed that he totaled(That I just built an engine for with headstuds, swamps injectors, new clutch, etc) and wants to use the engine and transmission in an '03 6.0 auto truck he just bought.
Anyone have experience with this? Hope going to the 'dumb' transmission will make things go a little smoother but I know that the center 'hump' in the cab is different from an auto to a 6 speed.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #6 of 17 (permalink) Old 02-19-2011, 12:47 PM
mwalsh9152's Avatar
As long as you have the complete donor it will be plug and play. On my Bronco I had to swap out the dash and engine harness along with both fuse box's, but the existing chassis harness and most of the interior plugs worked. Going from one diesel to the next you will probably have a lot less to swap than I did. Dash harness will likely be the same, you may just need to swap the engine harness, which is pretty simple.
As for the dumb transmission, I remember seeing one conversion where the guy cut the transmission hump out of the donor and grafted it into his truck.
1995 7.3 Bronco
mwalsh9152 is offline
post #7 of 17 (permalink) Old 02-21-2011, 07:42 PM
FUMMINS SPECIALISTS
GOSSteel's Avatar
The 03 is a split year for the 6.0 and 7.3, so everything will be fairly simple. Ford to Ford is still easier than Dodge to Ford, although we specialize in Fummins!
GOSSteel is offline
post #8 of 17 (permalink) Old 05-27-2011, 06:08 PM
truckpullin_75's Avatar
Looking to do the same thing with mine. Have a fully built 7.3 in a rolled truck, engine wasn't hurt and neither was I thank god. Looking at buying a like-bodied 03 or 04 king ranch or harley edition and swapping out the 6.0 and 5r100 for a 7.3 and bts 4r100. Kept the truck so I still have all the wiring harness, cluster, etc. Even if I end up buying another 7.3 the engine is going to come out for the built one so the labor part of it shouldn't be much more intensive....I hope. Exactly what all would have to be swapped over??
truckpullin_75 is offline
post #9 of 17 (permalink) Old 05-27-2011, 06:56 PM
OBS junkie
Cat_Rebel's Avatar
We're doing a 99 V10 gasser to 00 7.3L swap, we'll find out how everything works soon.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #10 of 17 (permalink) Old 05-28-2011, 03:33 AM
Modded by a Chevy Express
Alberta 7.3's Avatar
In '02 they changed the instrument cluster, and the power distribution was all moved to one fuse panel under the dash. The 2000 harnesses/power distribution will be completely different from the '03. The 02 and later cluster needs an 02 and later 7.3 PCM/related wiring for the WTS/WIF lights to operate correctly. You'll be able to swap in the 7.3 but probably need a 02-03 7.3 engine harness and PCM to avoid having to rewire the entire truck.
96 F250 SC/SWB/4X4 XLT Just a 7.3 with a bunch of the usual bolt-on crap
08 F350 CC/LWB/4X4 DRW Lariat
Alberta 7.3 is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/28-engine-transmission-conversion/84483-6-0-7-3-conversion.html
Posted By For Type Date
6.0 to 7.3 Conversion Kit_Yaelp Search This thread Refback 11-26-2015 07:46 AM
