4R100 to a 5R110 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 45 (permalink) Old 11-11-2007, 01:54 AM Thread Starter
heep70's Avatar
4R100 to a 5R110
I really don't know to much about the 5R110 yet. I don't hear anything bad about them as far as failing.
Are the 5R110 autos any good?
Will the two trannies will interchange without any mods (4R100 to a 5R110).
Greg
2000 PSD F250 4X4 Crew, John Wood 4R100, DP Tuner, 4" Diamond eye, Tymar, LIFT, 35" Toyos, Pillar gauges, TC lockup switch, 6.0L cooler, Single core rad, Most of all a Cool Driver, THATS ALL.
heep70 is offline
post #2 of 45 (permalink) Old 11-11-2007, 03:33 PM
Proud PSN Sponsor!
Strictly Diesel's Avatar
Re: 4R100 to a 5R110
No, they will not directly interchange.
Keep your 4R100, you're better off!
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Strictly Diesel is offline
post #3 of 45 (permalink) Old 11-11-2007, 06:26 PM Thread Starter
heep70's Avatar
What is the bad new on the 5R110?
I have been told by others to not mess with it.
Greg
heep70 is offline
post #4 of 45 (permalink) Old 11-12-2007, 06:41 AM
gregrob's Avatar
There aren't enough aftermarket parts available to make it near as strong as the 4R100 can be made.
There are a small handful of builders who have the 4R100 NAILED! It can pull, shift, and last like a dream with the right parts and know how to put it together.
gregrob is offline
post #5 of 45 (permalink) Old 11-16-2007, 08:47 PM
OBS junkie
Cat_Rebel's Avatar
Yep, the 4R100 is a good tranny that can be made to hold up to alot of power.
Has anyone even put a Torque Shift on a 7.3L?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 45 (permalink) Old 01-17-2008, 02:14 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Nobody has, and I doubt that anyone ever will. Here's why:
It's WAY harder to make software shift a TorqShift than a 4R100, due to the design of the two transmissions.
The 4R100 is an all non-synchronous design. This means that for each upshift all that happens is a clutch is applied. All you need to do is control the pressure to the oncoming clutch and you're all set.
The TorqShift is MUCH more complicated. The 1-2 and 5-6 shifts are the same, they are non-synchronous and all you need to do is control the pressure of the OD clutch. The other shifts are the problem.
The 2-3 is a swap shift. This is a special catagory of difficult shift. I believe Ford is the only trans maker in the world that still does swap shifts. Others have put swap shift transmissions in production and then replaced them within a few years. To make a swap shift the TorqShift needs to release the OD clutch to downshift the OD gearset while applying the intermediate clutch to upshift the Simpson planetary gearset. This is an upshift and a downshift occuring at the same time in the same trans. From my experience these two shifts MUST complete within 30 milliseconds of each other or it's going to feel awful. If the OD releases too soon the engine speed will flare. The amount of flare is dependant on how much sooner it completes. If it completes before the intermediate has enough capacity the trans goes back to first gear! Then it has to make a 1-3 shift. A few WOT 1-3 shifts means the trans comes out to replace the intermediate clutch. Been there, done that. If the OD releases after the intermediate comes on you end up in 4th gear (1.09:1 ratio) then downshift back to third gear (1.54:1 ratio.) Either way it's really bad.
Now if you made it though that you need to make a 3-5 shift. 4th gear is the 1.09:1 ratio that really isn't used. The 3-5 is a synchronous shift. It's timing requirements are about the same as the swap shift, but there is no downshift. To make the shift the intermediate clutch has to release while the direct clutch applies. If the intermediate releases too soon you get an engine speed flare. If the intermediate releases too late you get a tie up. A tie up is when all three pieces of the planetary gear set are held from turning. This means the output shaft of the trans STOPS. That's not a pleasant thing to have happen when you're at WOT making a 3-5 shift. You can lock the wheels on an upshift! I've done this, too. You can also break expen$ive parts doing a tie up.
Now start thinking of the combination shifts that can happen. How about cruising at 55 MPH behind some slow poke on a two lane road? A passing zone opens and you floor it. Now you may want to go from 6th to 3rd gear. You need to release the direct clutch and apply the intermediate. That's a synchronous shift in reverse.
As you can see from just these few examples it isn't a trivial task to make one of these transmissions shift. It's what I did at Ford for quite a few years, three of them working on the TorqShift. I'd be really surprised if anyone makes a controller for the TorqShift that works really well. I think someone could make one that does some basic shifting, but getting one so that it shifts at least as well as a stock trans is going to be a HUGE task.
Mark Kovalsky is offline
post #7 of 45 (permalink) Old 01-17-2008, 03:52 PM
TurboChris's Avatar
Holy Crap......great info...thanks!
01 250 4x4 CC Lariat - 9" Lift, 38" PJ's, Warn M12000, Fox Shocks, 4.56 Gears, Amp Running Boards, Gauges, DP Tuner,AFE, 4''exhaust & more
TurboChris is offline
post #8 of 45 (permalink) Old 01-17-2008, 03:53 PM
2Cruel
moremph's Avatar
I was told be a reputable trans builder that thier main fix for a 6.0 making power is to pull the 5r110 and put in a 4r with a standalone!!
Travis
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
post #9 of 45 (permalink) Old 01-17-2008, 06:37 PM Thread Starter
heep70's Avatar
Geez that sounds like something to stay away from. Great info, thanks for sharing.
Greg
heep70 is offline
post #10 of 45 (permalink) Old 01-18-2008, 12:39 AM
OBS junkie
Cat_Rebel's Avatar
Thanks for the info Mark. What do you think of Destroked offering a kit to mate a 5R110 Torqueshift to a Cummins?
http://destroked.com/parts.shtml
RIP Will Iott
Human Verification
