12 MPG???? with a 1996 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 06-19-2010, 04:26 AM Thread Starter
I have a 96 f350 crew cab long bed. Built e4od. 3.5" straight thru exhaust. Tymar intake. Tony Wildman tunes. 4.10 rear end. New 315/75/16 AT tires. I dont drive it very hard and I average 12 MPG and thats mostly highway. I cruise at 2200 rpm. When I pull my 6500 lbs trailer I get 8 MPG. Any ideas on what to check? It seems llike most guys are getting 15 -16. I would love that. Thanks
Big Red F350 is offline
post #2 of 26 (permalink) Old 06-19-2010, 04:33 AM
Re: 12 MPG???? with a 1996 7.3
up-pipes leaking? when was your last oil change? what psi are the tires at? any brakes dragging?
02 f250
countryboyrob is offline
post #3 of 26 (permalink) Old 06-19-2010, 04:40 AM
redneck engineer
olsmokey's Avatar
swap to 3.55 gears
97 f-250 hd solid axle cold air 4in dp 3in body lift 4in exhaust rollin on 36 12.50 swampers hopfully have 46's under it this fall
olsmokey is offline
post #4 of 26 (permalink) Old 06-19-2010, 04:48 AM Thread Starter
oil changed about 8 months ago and used a motorcraft filter. I dont think the up pipes are leaking. Tires are aired to 44psi. Also forgot to mention i have a 3" downpipe. I havent checked the brakes.
post #5 of 26 (permalink) Old 06-19-2010, 04:53 AM
What Fire?
Big Green's Avatar
Have you changed out the injectors?
96 F350 Crew Cab 4X4
Tymar Intake, 4" Chino Valley Muffler Exhaust, Custom Uncool Intercooler, 3 Guage Pillar, Stage 2's, BTS Transmission,
Neck Snapping Power.
Big Green is offline
post #6 of 26 (permalink) Old 06-19-2010, 05:26 AM
oil burner
tughill283's Avatar
too many rpms,get bigger tires or higher gears,or go slower.keep it under 2000 rpms for best fuel mileage.
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #7 of 26 (permalink) Old 06-19-2010, 06:25 PM Thread Starter
It has stock injectors with 140k. Does everyone else just drive their trucks between 55 mph and 60 mph?
post #8 of 26 (permalink) Old 06-19-2010, 08:06 PM
MPG Moderator
Dave Whitmer's Avatar
Nope. I drive 60 and 70 MPH.
You have a low-MPG configuration.
The automatic is killing you. The 4x4 costs you 2-3 MPG. The CC is heavy.
The big wheels are kickin' your butt.
You didn't mention a tonneau, so I assume your are running open bed.
Wildman tunes may improve your acceleration, but in that draggy configuration that just means a faster fuel burn rate.
If you can't change the configuration, your choice is stark: Slow down or eat the poor fuel economy.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #9 of 26 (permalink) Old 06-19-2010, 11:12 PM
8 months ago = how many miles? also is your firewall covered in soot?
44psi is a little low, I would sir them up to atleast 50psi
02 f250
post #10 of 26 (permalink) Old 06-20-2010, 12:11 AM Thread Starter
No soot on the firewall. I have only put on 800 miles since the oil change. The truck usually only gets about 1200 miles a year on it.
Human Verification
