cummins 12v mpg vs 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 05-12-2009, 12:01 AM Thread Starter
jaybuller's Avatar
Alright heres my question, does a 2500 club cab 4x4 12v 1998 12v cummins with auto trany get as good or better mpg than a 2001 4x4 7.3 auto super cab? both trucks fixed up comparably with about 400hp? and driven by the same person the same way?
Im in the position to help a buddy out with witch truck to get he does want the best mpg in a diesel truck
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #2 of 17 (permalink) Old 05-12-2009, 12:04 AM
all ur OBS r belong to me
OldschoolPSD's Avatar
Send a message via MSN to OldschoolPSD
Re: cummins 12v mpg vs 7.3
The cummins will do better. I still get 19mpg with mine, and its in a brick truck lifted on 35's.
Ford stopped building trucks in 1997
OldschoolPSD is offline
post #3 of 17 (permalink) Old 05-12-2009, 12:17 AM
CLARKY
smokinndstrokin's Avatar
My 93 Cummins would consistantly get 19-20mpg no matter what,loaded,unloaded,highway,backroads.My 01 stroker can only touch that on highway w 35's,cruisin 65 it has gotten 23mpg.FWIW
2001 F350 SD K&N intake tube w amsoil filter nd prefilter,4in turbo back to 6in tip,TS chip,,isspro guages(poost,pyro,trans)AIH delete,CCV, Dr.evil trans w 3 disk lock up converter by Hughes,wicked wheel,Mag hytec covers with many more mods to come
smokinndstrokin is offline
post #4 of 17 (permalink) Old 05-12-2009, 12:18 AM Thread Starter
jaybuller's Avatar
thanks 19 is perty good, i get about 19 in my psd but mines is built for mpg with about 350 hp and stock suspention and small stock size hyway tires.
post #5 of 17 (permalink) Old 05-12-2009, 12:34 AM
MPG Moderator
Dave Whitmer's Avatar
In a straightforward, no BS test...probably about the same. Unloaded the Dodge, being built lighter should do a little better.
I have called for a MPG road trip with Dodges and Cheviies. Nobody ever takes me up. Wonder why not?
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #6 of 17 (permalink) Old 05-12-2009, 01:56 AM
That thing got a Cummins?
nasty96's Avatar
Cummins will get a little better mileage.
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #7 of 17 (permalink) Old 05-12-2009, 04:13 AM
Harry Callahan
My 12v gets around 17, the same truck with a 7.3 got about 14. 7.3 was 500 hp, 12v is way more.
RDRCM#10
A select band of brothers- We stand together as one.
Giant VT-3, not stock
sniperonhigh is offline
post #8 of 17 (permalink) Old 05-13-2009, 02:10 PM
Dodge should get a little better, it has 3.55 gears and smaller tires factory anyway. Plus as Dave noted it is a lighter weight truck.
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #9 of 17 (permalink) Old 06-15-2009, 11:32 PM
Bandwagon Jumper
19_A_LT's Avatar
sorta makes sense about the mileage. 7.3 is only 1.4 liters bigger than a 5.9. of course the dodge will get better mileage granted it doesnt have massive problems and real low gears. talked to aguy that was getting 26 with 3.55 gears about thsi time last yaer. you can get around 22-24 mpg with a 7.3 running 80 consistently with 3.08 gears though.
19_A_LT is offline
post #10 of 17 (permalink) Old 06-24-2009, 11:15 PM
In my experience a 12v will get 3-5 more mpg than a simular 7.3,towing
heavy even more.
2000 F-350 6 sp. 4.5 DR air, fuel,exhaust mods.
dreadnaught is offline
Human Verification
