32 mpg 6.0L - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-17-2012, 07:59 AM Thread Starter
7.3HD Guy's Avatar
32 mpg 6.0L
My BS meter is going off on this one. What do you guys think? He lists some stuff he did to it but I'm thinking mid 20s at best. Check it out.
97' F-250HD SCLB 4x4 5spd
7.3HD Guy is offline
post #2 of 10 (permalink) Old 04-17-2012, 09:38 AM
klipz's Avatar
Re: 32 mpg 6.0L
I'd like to see what hand calculated numbers are, and what propane system he is running?
2002 F350 CC short bed, 3.73's, 3" leveling kit, 33" nitto's, cowl hood, 4" straight exhaust, 7" stacks, cold air intake, homebrew boost reg., wicked wheel, banks transcommand, Dp-tuner, and a really BIG wish list!
klipz is offline
post #3 of 10 (permalink) Old 04-17-2012, 09:56 AM
Monster758's Avatar
Re: 32 mpg 6.0L
It's called the lie-O-meter for a reason lol. I could see 19-21 mpg hand calculated.
2005 F-250 Custom 4" TB exhaust, AFE Stage II, High Idle Mod, CCV Mod, 6 Inch Fabtech, 35/16 wide Dick Cepek tires
Monster758 is offline
post #4 of 10 (permalink) Old 04-17-2012, 08:26 PM
MPG Moderator
Dave Whitmer's Avatar
Re: 32 mpg 6.0L
It doesn't appear that he is accounting for the propane.
That would be appropriate if he got his propane for free, but I doubt he does so.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #5 of 10 (permalink) Old 04-17-2012, 08:46 PM
Don 6.4's Avatar
Re: 32 mpg 6.0L
I had a 6.0 that got that good of fuel millage on almost every tank. Only because it broke down on almost every tank and was on a flatbed for at least a hundered miles to get to the dealer I bouget it from.
Don 6.4 is offline
post #6 of 10 (permalink) Old 04-18-2012, 06:43 AM Thread Starter
7.3HD Guy's Avatar
Re: 32 mpg 6.0L
I read some of the posts and he claims he hand calculated it over and over. Apparently hes bad at math.
post #7 of 10 (permalink) Old 04-18-2012, 09:00 AM
klipz's Avatar
Re: 32 mpg 6.0L
Hey Dave,
Could it potentially be worth it if you ran the propane and actually saw an increase like this in mileage or at least similar to this. If so, what kind of propane system would you need and what affects on the motor would the propane cause? What about compressed natural gas as an option, that might be cheaper than propane? Hell if its possible, I have a decent sized stainless tank we took off of a truck at work I might be able to use?
klipz is offline
post #8 of 10 (permalink) Old 04-18-2012, 08:16 PM
MPG Moderator
Re: 32 mpg 6.0L
It all depends on how much each fuel costs.
Around here diesel goes about $4.09/gal ($29.21/MMBTU)
Propane goes about $2.79/gal ($29.36/MMBTU)
CNG goes for around $1.50/gge ($12.50/MMBTU)
That's retail at a filling station set up for fueling motor vehicles.
CNG has an advantage because its not taxed. That will certainly change, at least in commercial filling stations.
Propane and CNG are just auxiliary fuel. By themselves they'd never run a diesel as their cetane rating is too low. In a diesel you used the No.2 injector as a spark plug to blowtorch the aux fuel into burning.
The guy is not being honest with us (or himself) because he is not telling us the propane flow rate.
CNG requires tanks and piping rated for either 3,000 or 3,600 psig. Don't know about propane. To make CNG you need a compressor that looks a lot like a scuba air compressor but with a bigger aftercooler.
There is (or was) a home CNG compressor called a PHYLL that would take a day or two to fill a 10 gallon equivalent CNG tank. It needed 240 V power and a regular residential gas service. A big (more commercial style) Ingersoll-Rand compressor needs a 480V 3 phase service and 50 psi gas service. It will fill up a 10 gallon equivalent tank in about 12 hours.
If I had an economical source of either gaseous fuel I'd use it in a spark-ignition engine. It would be simpler.
Slammed 4"
Rugged Air Dam
315,000 miles
post #9 of 10 (permalink) Old 04-18-2012, 08:41 PM
ewxlt's Avatar
Re: 32 mpg 6.0L
Mine gets between 13.3 and 13.7 whether I'm empty or loaded.
2006 F250 CC FX4 leveled on 285/75/18
by
, on Flickr
ewxlt is offline
post #10 of 10 (permalink) Old 04-18-2012, 10:12 PM
Jack Ken
Re: 32 mpg 6.0L
He should be in the area of about 20% LP, much more and it will cause trouble. so take 40mpg x 20% and thats about 32. take 32 x 20% and thats about 26. But its hard to stay at 20% without computer controls. There is a system out there, I install them but Im not going to advertise on here. We see roughly 20-30% increase in mpg with it to give you an idea.
2003 Exursion 7.3 diesel exhaust, intake, ts chip, banks exhaust housing, big head actuator all sittin on 20s w/ 35s.
1989 F350 460 propane, 4inch lift 39.5s
1988 bronco ii 2.3 turbo motor on propane
fordman2121 is offline
Human Verification
