ZF6 problem : ( - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 01-14-2011, 02:28 AM Thread Starter
Jbstroker87's Avatar
ZF6 problem : (
Well hell! Take her for a spin after doing injectors, studs blah blah all the goodies, truck does just fine for about 50 miles tonight. Coming down the highway a yellow light flashes so i go to downshift and BAM!!! rear tires lock up for a second, and everything is fine. I'm thinking weird!!! okay well i pull over and put it in neutral, it's stuck in gear while the shifter is in neutral. i know it's stuck somewhere between gears, and it's a long shot but has anyone ever had this happen? the truck only has 150k on it and these trannies are pretty tough but any ideas on what is wrong??????
Jbstroker87 is offline
post #2 of 10 (permalink) Old 01-14-2011, 02:39 AM
Re: ZF6 problem : (
mine did the exact same thing....except i had 8 round hay bales behind me...had to have it rebuilt. can remember exactly what the guy said had happen/caused it but it was stuck in 4th....i'm wantin to say the syncros went out and locked it in gear and wouldn't let it release but can't remember...(2yrs ago)
2006 f-250 ext cab swb, 127,000mi, Egr delete, 4" tb exhaust, edge juice w/ cs.
Ryan
dp_stroker is offline
post #3 of 10 (permalink) Old 01-14-2011, 03:02 AM Thread Starter
Re: ZF6 problem : (
Lovely!! well thanks!!!! I run a hay crew in the summer so it has been abused a little ha ha! any idea on what it ran you??? i just dropped 3500 on everything, i just did and my pockets are getting more and more shallow!
post #4 of 10 (permalink) Old 01-14-2011, 03:08 AM
PSN Pontiac Enthusiast
b00stleak's Avatar
Re: ZF6 problem : (
shift forks? my getrag was doing that same thing for a while. turned out the pilot bushing went out and that in turn eventually led to it eating a shift fork. still putting it back together
b00stleak is offline
post #5 of 10 (permalink) Old 01-14-2011, 10:37 AM
Re: ZF6 problem : (
i finially found a guy about 3 hours away to do it for 1500 bucks but everybody else i priced was 1800-2200...and i found brand new ones for around those same prices. mine gets abused badly during hay season also...but since i've had it rebuilt not one problem at all besides trying to keep a clutch in it...different story though..lol
Ryan
post #6 of 10 (permalink) Old 01-15-2011, 03:45 AM
oilfield trucker
zpilgeram's Avatar
Re: ZF6 problem : (
I had one do the same thing, turned out the bearing went out of the reverse gear and would'nt allow the output shaft to turn.
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #7 of 10 (permalink) Old 01-15-2011, 06:40 PM Thread Starter
Re: ZF6 problem : (
wonderful... well luckily i found out i have a warranty that is still valid on the tranny, thank god!!! 2800 that i don't have to pay to get it rebuilt. is there any parts for the zf6 that i can get so i don't tear this one up??? perhaps input and output shafts? better bearings? gears? anything???
post #8 of 10 (permalink) Old 01-17-2011, 02:10 AM
b00stleak's Avatar
Re: ZF6 problem : (
you my friend dodged a bullet with that warranty :)
post #9 of 10 (permalink) Old 01-17-2011, 03:01 AM Thread Starter
Re: ZF6 problem : (
Oh yeah! Saved me around $2800
post #10 of 10 (permalink) Old 01-17-2011, 04:29 AM
Dieselgeek's Avatar
Re: ZF6 problem : (
Whatever gear you have while in neutral is the bearing you locked up... I fried mine a few weeks back, had low gear only, that was a slow trip home...
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
Human Verification
