Must "wiggle" gear shifter for truck to start... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 12-02-2010, 05:45 PM Thread Starter
This has been happening more and more lately. The truck will not engage the starter unless I wiggle or move the gear selector lever in and out of Park a time or two. I have heard of this issue before, but couldn't remember the exact cause. Is this the park/shift lock switch/solenoid inside the steering column causing this? I have also heard that maybe it's the "digital transmission range sensor" on the tranny. It seems to basically be telling the ECM to not allow a start cycle because the truck is not fully in Park. Any other ideas with this? Thanks.
Early 99 (build 04/98) F250 XLT Supercab, 7.3 PSD, 4x4, 4R100, SRW, 6637 DIY intake, 4" TB exhaust, RCD leveling kit, 05 front facelift, 05 tow mirrors, 05 body badging, 05 Dash, Body molding delete, Difuser headlight harness, 20x10 XD Diesels(black), 305/55/20's, Stainless brake lines, Updated PCM, White face gauge overlay, 2002 seats.
Early99PSD is offline
post #2 of 14 (permalink) Old 12-02-2010, 06:08 PM
SouthFlstrokin''s Avatar
Re: Must "wiggle" gear shifter for truck to start...
maybe the neutral safety switch
Early 99 7.3 2wd
Old truck with all the bells and whistles....
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
SouthFlstrokin' is offline
post #3 of 14 (permalink) Old 12-02-2010, 06:41 PM
undercompensating
JMart's Avatar
If there is slop in your selector the start looking into the column, if not I would consider the neutral safety switch. My selector has slop so I know I need to replace the bearing. I have to push it up into park sometimes to get it to start. Or I just put it in neutral first.
Jason
JMart is offline
post #4 of 14 (permalink) Old 12-02-2010, 06:57 PM
<---- my shop
vader's fury's Avatar
There are 2 bushings on the steering column that could be bad, or I have seen the bolts on the end of the shift column come loose and cause this issue. I would start there first. Have you done any trans work on truck lately?
Robert
2003 F-350 CCLB, 7.3, Auto
2000 F-450 Sold.....
vader's fury is offline
post #5 of 14 (permalink) Old 12-02-2010, 07:08 PM
x2 very common.where the cable connects to the linkage,it is bolted with two bolts.had that problem with two different trucks.the first time i didnt know what was goin on until one of the bolts fell out of it onto my foot.
skippy is offline
post #6 of 14 (permalink) Old 12-02-2010, 07:14 PM
R.I.P PSN
TheSmokinStroke2002's Avatar
try putting it in neutral and starting it
Konnor
2002 Ford F-350 CCSB 7.3
Diesel Innovations Tunes
Glowshift 10 series gauges
6637 Intake w/ Truckmods cover
Foil Delete
Wicked Wheel
Dual 7" Aussies
5" lift
35" MT ATZ's
Black MT Classic Locks
03-07 Tow Mirrors
05 Harley front end
Recon Smoked cab lights
ATS Stage 3 Trans w/ 5 Star Converter
R.I.P. Will Iott
TheSmokinStroke2002 is offline
post #7 of 14 (permalink) Old 12-02-2010, 07:15 PM
dieselsmoke0204's Avatar
That was the issue for me. Look under the dash in the steering column and there should be 2 or 3 gold bolts. When you wiggle the shifter you will see them move. Those bolts were loose and I had to hold it up in park for it to start. All I had to do was tighten those bolts and it was all good.
Andy
2000 F350, Dually, 6speed, Flatbed, snow plow - Work Truck / Tow Pig
01 Silver PSD, lifted, roof rack, winch, snorkel- SOLD
03 Jetta TDI- DD
1999 Jeep Cherokee, lifted, locked, etc....
dieselsmoke0204 is offline
post #8 of 14 (permalink) Old 12-02-2010, 07:23 PM
All done now
Arisley's Avatar
One of the first issues I ever had with my truck. A drop of blue loctite, no issues since than.
Arisley is offline
post #9 of 14 (permalink) Old 12-02-2010, 07:31 PM
No 6.0
zaairman's Avatar
Easiest way to fix this problem is to have Andy come over and fix it for you...
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
zaairman is offline
post #10 of 14 (permalink) Old 12-02-2010, 07:32 PM
All done now
Arisley's Avatar
No problem, I could use a trip to CA.
Arisley is offline
Human Verification
