5R110 Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 41 (permalink) Old 02-29-2012, 02:04 PM Thread Starter
IH Diesel Power
Petro's Avatar
5R110 Problems
Alright I swapped a used trans with 70K into my 08 6.4. From the Start the trans always seems to take off in 3rd gear, wont shift up or down and the TC never locks up. It throws the code P215b, says something about the output shaft speed. If i clear the codes, it take off normal but then starts to act funny right about the time it wants to shift then throws the same code and goes back to 3rd gear. Now the trans is gurenteed to to be good, I beleive the guy but id like to figure this out because i really dont want to pull it back out and go through all that hassle again because its kind of a b*tch. Any help or suggestions would be great, im kinda lost here and considering taking it in to a shop and seeing what they tell me, Im just scared they are goin to say its bad even if its not just to get me to have it rebuilt.
Current
99/05 F250 XLT Ccsb 4x4, 7.3l, ZF6
, Power Struck Tuned, Luk Clutch, RR, Comp 910s, and more sh!t.
Sold
99 F250 Lariat Ccsb 4x4, 7.3L, 4R100, The Basics
Totalled
08 F250 Lariat Ccsb 4x4, 6.4L, 5R110, SCT Livewire IDP Custom Tuned, 5" Exhaust, Custom Traction Bars.
Petro is offline
post #2 of 41 (permalink) Old 02-29-2012, 04:04 PM
bracketracer's Avatar
Re: 5R110 Problems
Any other codes set?
What happened to the previous trans?
Do you have access to a scan tool to check the reading from the VSS and OSS?
If there's no other codes set, do you have a known good TCM you can swap in to try?
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #3 of 41 (permalink) Old 02-29-2012, 07:30 PM Thread Starter
IH Diesel Power
Petro's Avatar
Re: 5R110 Problems
That is the only codes its throwing, at first it was throwing another vehical speed sensor code but it quit doing that. Cant remember which code it was. The previous trans took a dump, was getting weak then took it to check cows one day and the snow got a little deep and I melted the clutches together without getting it hot, reverse and neutral were both forward gears. No I dont have access to ascan tool or another tcm.
Current
Sold
Totalled
Petro is offline
post #4 of 41 (permalink) Old 02-29-2012, 09:23 PM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: 5R110 Problems
Ur old trans wasn't fried, you had a solenoid stuck open
Fordfreak4life is offline
post #5 of 41 (permalink) Old 02-29-2012, 10:24 PM Thread Starter
IH Diesel Power
Petro's Avatar
Re: 5R110 Problems
How does that help me? Would a solenoid stuck open burn the piss out of the fluid? I could smell the burnt fluid from in the cab and I only had first gear. None the Less, That trans is gone and I need to get this one figured out. I need my truck and some helpful input would be great.
Current
Sold
Totalled
Petro is offline
post #6 of 41 (permalink) Old 02-29-2012, 11:59 PM
Haters Gonna Hate
Re: 5R110 Problems
Get it on a Ford ids do you can view live data
post #7 of 41 (permalink) Old 03-01-2012, 02:53 AM
Re: 5R110 Problems
How did you melt the clutches and burn the fluid "without getting it hot"??
Seriously though, if that's the only code is has you need to get the VSS and OSS checked on a scan tool to make sure they're both in spec. If they are, then you replace the TCM.
post #8 of 41 (permalink) Old 03-01-2012, 02:59 AM
One of a kind
PSD-BLACK-CLOUD's Avatar
Re: 5R110 Problems
I feel your pain mine has been sitting at ford since friday.
2010 F-350, Auto,4X4, 4dr long bed, SCT/Gearhead, S&B, High Idle,Guages:boost,egt,trans, 2.5" Leveling Kit/Track Bar, PMF bars, 325-60-20's on 20x10 XD Revolvers
PSD-BLACK-CLOUD is offline
post #9 of 41 (permalink) Old 03-01-2012, 10:22 PM Thread Starter
IH Diesel Power
Petro's Avatar
Re: 5R110 Problems
I Wish I knew, Trans temp never got above 150 or 160, I was closely watching it like I always do. It was getting tired already, a few to many runs in the hot EX Race. But I was looking today and may have found the problem. The sensor on top of the output shaft, possibly the output shaft speed sensor? was plugged in but not locked. I took the sensor out, and both ends are clean but for some reason it just wont slide far enough in to lock even with a large amount of force. The connection slides together but only about 3/4 of the way. Goin to order a Output shaft speed sensor and see what happens. This is really pissing me off Already. I wish I could afford to just take it to ford, but I know how that would turn out with the way our dealerships are around here. . . . . . .
Current
Sold
Totalled
Petro is offline
post #10 of 41 (permalink) Old 03-01-2012, 10:29 PM Thread Starter
IH Diesel Power
Petro's Avatar
Re: 5R110 Problems
Sucks doesnt it? I see in your signature that your have a SCT TSX, Is that the touch screen? If so how do you like it, kinda been thinkin bout getting one.
Current
Sold
Totalled
Petro is offline
Human Verification
