Diesel Fuel Gel test - Pwr Srvc, Howe's, Schaeffer - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 61 (permalink) Old 03-06-2010, 01:41 AM
bobvillaoftn's Avatar
Re: Diesel Fuel Gel test - Pwr Srvc, Howe's, Schaeffer
awesome apparently #1 is chemically balanced not to gel until lower temps.
05 f350 CCLB 4x4 delete and sct x4 thanks to innovative
Originally Posted by RedSmokey View Post
Sh*t in a box (litterally) and write "Will give you 200+ hp, just add to your fuel" on the box and give it to him. Then ask him if he still believe's everything thats written on a box...
Originally Posted by bruce51d View Post
if you can blow up a 7.3 just imagaine what you would do to a 6.0
bobvillaoftn is offline
post #12 of 61 (permalink) Old 03-08-2010, 03:38 PM Thread Starter
Freedom is not free
White Buffalo's Avatar
Correct, #1 Diesel has a gel point closer to -35F to -40F. The negative aspects are that #1 drops the Miles Per Gallon about 1-2 mpg on average. In addition, #1 does not have the same lubricity as #2. Most folks up here will run a 50/50 mix of the two. Last year (here locally) #1 was .40 cents per gallon more that #2, so the cost per fill up went up quite a bit. That is where some additives can come in to play, if the additive will only cost a few cents per gallon and can effectively drop the gell point than you can save approx. .35 cents per gallon. This year (here locally) the price difference between #1 and #2 was only about .15 cents - so it wasn't as huge of a cost savings as last year.
White Buffalo is offline
post #13 of 61 (permalink) Old 03-08-2010, 03:58 PM Thread Starter
Freedom is not free
Here are some additional pics on the water contamination test I mentioned I wanted to add to this post. Sorry it took so long for me to get this posted.
Many folks initially jump to gelling as being the problem during cold temps, but water contamination can cause problems much quicker than gelling. The water in these samples froze at the bottom of the containers within one hour.
Again, not a very scientific study or analysis - just a good visualization so we can get a better understanding of what might be going on inside the tank and/or engine.
According to the Standard, Diesel fuel can contain up to 100 ppm water. Most suppliers try to keep this under 50 ppm especially during the winter.
This is a #1 Diesel Sample with 2cc's of water added. The pic is a little fuzzy, but you can see the water droplets at the bottom of the sample.
This is a #2 diesel sample with 2 cc's of water added.
Here is a photo of both contaminated samples with Schaeffer's Winterized Dieseltreat additive that contains a water dispersent. It does seem that the additive was a bit more effective in the #1 diesel than in the #2 to the naked eye.
I'll add more info later. ran out of time for now.
post #14 of 61 (permalink) Old 03-08-2010, 08:30 PM Thread Starter
Freedom is not free
here is a better close up pick of the contaminated samples with the 137ULSW additive.
post #15 of 61 (permalink) Old 03-08-2010, 09:21 PM Thread Starter
Freedom is not free
Correction: I said the limit for water in Diesel was 100 ppm, that is not correct. It is higher than that. I need to find out what the ASTM standard is.
edit: from what I have found the allowable level is .05% which should equate to 500 ppm.
post #16 of 61 (permalink) Old 03-09-2010, 12:06 PM
awesome info! btw nice house.
post #17 of 61 (permalink) Old 03-10-2010, 01:59 AM
OEM Moderator
Tom S's Avatar
I made this a sticky in this section since there is some very good information in here. I also left the thread open so that others can add to this discussion or Rich can add information. Thanks Rick.
Tom
Tom S is offline
post #18 of 61 (permalink) Old 03-11-2010, 06:38 PM
oil burner
tughill283's Avatar
wow i guess i was lucky to get through the winter on straight no 2.i even had some oil mixed with it a few times and im sure that dont help.
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #19 of 61 (permalink) Old 10-27-2010, 02:52 AM
Missouri 05
flyboy41's Avatar
my 1st year with a diesel....What is the temp that you have to worry about the fuel gelling? I am in the KCMO area and it is still in the 40s at night.
flyboy41 is offline
post #20 of 61 (permalink) Old 11-08-2010, 04:08 AM
scott2001's Avatar
no one has said this. BUT good god its cold where you live.
I do belive my blood would freeze their
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes All deletes done now.
flow pro hot pipe. CCV mode.
2013 dodge charger
scott2001 is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/24-fluids-discussion/53695-diesel-fuel-gel-test-pwr-srvc-howes-schaeffer.html
Posted By For Type Date
Power Service - Chevy and GMC Duramax Diesel Forum Post #0 Refback 09-10-2016 03:20 AM
fuel additive - Page 2 - Diesel Place : Chevrolet and GMC Diesel Truck Forums This thread Refback 01-18-2016 03:48 AM
MUST READ intrested thread on Fuel Geling - Chevy and GMC Duramax Diesel Forum Post #0 Refback 11-29-2015 02:32 AM
Diesel Fuel Gel Test - TheDieselGarage.com This thread Refback 11-08-2015 04:24 AM
