E-450 general questions...... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 11-09-2012, 06:45 PM Thread Starter
Always Learning
Just picked up a 1997 E-450....as you guessed 7.3l. I started going over it today and have run into some things that I wanted some answers about.
1. I started with air intake removal.....What in the world is this (pointing to in the picutre)? It is a big empty box....why is it there? does it have any real point? can I remove it? Does anyone make a aftermarket cold air intake for the van?
2. I pulled the cover in the cab, then the heat shield.......And to my surprize their was a EBPV. I was under the inpression that the vans did not have a EBPV? Was it only the 99 and up they deleted the EBPV?
3. I checked the door sticker and it shows a trans code of E. This is the E40D........I was under the impression that the E-450 and E-550 came with a more HD transmission. Is this E40D a beefed up version? Or is it the same one you find in the E-150/250/350?
Thats a good start......any help would be great.
bknight187 is offline
post #2 of 16 (permalink) Old 11-09-2012, 06:53 PM
Re: E-450 general questions......
Its called a resonator assbmlby
2000-7.3L is offline
post #3 of 16 (permalink) Old 11-09-2012, 06:54 PM
you can eliminate it, it does nothing, wont make it run bad or anything
post #4 of 16 (permalink) Old 11-10-2012, 03:44 AM
PSN Newb who's learning!
2002 E350's Avatar
you will get a little bit of drone noise inside when removing this resonator box.
2002 E-350 7.3 Power stroke 207,588 miles, Rotella 15w 40 All stock other than 4" Diamond eye turbo back Exhaust,16" MOTO METAL 951's
2002 E350 is offline
post #5 of 16 (permalink) Old 11-10-2012, 05:46 PM
Agree with 2002 E350, I have '97 and the I found the drone irritating si I out it back on, but that's just me.
I don't think anyone makes an aftermarket Intake. Do a search on this site and see what you find.
Good Luck.
stever88 is offline
post #6 of 16 (permalink) Old 11-11-2012, 12:03 AM
blageurt's Avatar
I have stated this numerous times.....the "resonator " is a POS ..who ever retains it is smoking really good green....... or is WAY too stupid to know the difference.....As soon as I realized I had to remove it to change my fuel filter , I replaced it with 2 Inch ABS piupe... You can also use PVC.... As far as the " Drone " discussion goes ..Turn up the sterio.....
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #7 of 16 (permalink) Old 11-20-2012, 09:02 PM
on a van you have to remove the dog house and get that thing out of the way to change fuel fillter i would pitch it just put aplug in i use pvc with some sealant
Bigstevex4 is offline
post #8 of 16 (permalink) Old 11-20-2012, 10:25 PM
old Smokey's Avatar
As far as i know the vans between 99-03 had no wastegate. I just installed a van set up on my obs off a 2001 f450. The vans seem to be half way between a SD and Obs turbo set up.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #9 of 16 (permalink) Old 11-21-2012, 03:55 AM
2002 E350's Avatar
WOW i'm stupid because i use my box.
UNSUBSCRIBE
post #10 of 16 (permalink) Old 11-22-2012, 12:39 AM Thread Starter
Always Learning
Any idea?
Human Verification
