non turbo 7.3 vs. reg. 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 11-05-2009, 08:31 PM Thread Starter
cattle farmer
powerstroke742008's Avatar
whats the difference between the two?
any internal diff.
etc.?
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
post #2 of 18 (permalink) Old 11-05-2009, 10:03 PM Thread Starter
cattle farmer
Re: non turbo 7.3 vs. reg. 7.3
bump anyone know?
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
post #3 of 18 (permalink) Old 11-05-2009, 10:09 PM
OBS junkie
Cat_Rebel's Avatar
Want to say something inside the turboed motors is suppost to be beefed up. Diffrent injectors & pump. In all truth though I would trust a NA motor with a turbo more then a factory turbo motor. Can't remember what it was but something they tryed to beef up didn't work so well & have been known to spin a bearing in the bottom end.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 18 (permalink) Old 11-05-2009, 10:11 PM Thread Starter
cattle farmer
so cat the non turboed does not use the huei system?
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
post #5 of 18 (permalink) Old 11-05-2009, 10:22 PM
OBS junkie
Cat_Rebel's Avatar
IDI & HEUI don't go together.
RIP Will Iott
post #6 of 18 (permalink) Old 11-05-2009, 10:25 PM Thread Starter
cattle farmer
i didnt know the non turboed 7.3 were idi
brain fart
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
post #7 of 18 (permalink) Old 11-05-2009, 10:47 PM
alleged moderator
tjctransport's Avatar
NA 7.3 IDI was 21.5:1 compression ratio.
turbo 7.3 IDI was 19:1 compression ratio.
powerstroke was a whole different engine.
tom
tjctransport is offline
post #8 of 18 (permalink) Old 11-05-2009, 10:54 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
For all this time I was under the impression that the factory turbo trucks had better rods, but this got me thinking and questioning myself, so I did some digging.
Found this...
Originally Posted by Agnem
The biggest improvement and most sought after option for 1993 was the introduction of the first factory turbo option. This option was available for the two remaining years of IDI production and is significant for several reasons. From the very beginning of the 6.9 liter production, a turbocharger was considered, but the normally aspirated engine was already a $2000 option and the addition of the turbo would nearly double that figure. Many believed that the extra amount on the sticker in the mid ‘80’s would put it over the edge price wise. Luckily, companies such as Gale Banks Engineering, Advanced Turbo Systems (ATS), and Hypermax saw this as an opportunity. ATS was chosen as the turbo system provider for the new factory turbo option and Ford/Navistar implemented other engine upgrades to compliment the addition of the turbo. Trucks equipped with this engine option can be identified by the small “Turbo Diesel” emblem under the F250/350 front fender badges.
The additional engine changes are as follows:
Cylinder head gasket heavier ring and armor wrap
Increased wrist pin bore on connecting rods
Larger wrist pin
Anodized piston head
Keystone design top and intermediate piston rings
Increased number of oil passages in oil cooler (30 fin/inch vs. 24 on NA)
Turbo specific flywheel
Turbo specific vibration dampener
Turbo injector pump
Turbo injectors
Modified injector fuel return line routing
Modified E4OD dipstick
Modified E4OD turbo micro processor
Turbo specific cooling fan clutch
Lower restriction exhaust
Additionally, the truck received a slotted front bumper and an air dam below the radiator. These improvements conservatively raised the power output to 185hp and 360ft/lbs of torque. These numbers are believed to be under-inflated so as not to downplay the mid year introduction of the new diesel engine.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #9 of 18 (permalink) Old 11-06-2009, 09:01 AM
alleged moderator
that's funny. the turbo diesel is the same HP, with a lower torque rating as my 88 idi was new.
tom
post #10 of 18 (permalink) Old 11-06-2009, 09:03 AM
alleged moderator
that's funny. according to that, the turbo engine had a lower hp and torque rating than my 88had when new.
my valve cover tag was for 195 hp.
tom
Human Verification
