Truck loses power and stalls going up hills - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-04-2012, 10:10 PM Thread Starter
I have a 1994 Centurian turbo 7.3 IDI. It sat for about a year or so before I got it. It has 102,000 miles on it, and I just got it about a month ago. I have put about 2000 miles on it, and the first 1500 had no issues what so ever other than a little bit of water in the bottom of the fuel filter twice (I check it all the time to make sure). I replaced the fuel filter right after I got it once I saw that there was a decent amount of water in the separator and I had no idea when it had been replaced last. I replaced it a second time when the fuel filter light in the dash came on. I drove the truck with no issues and towed with it all over the place, no issues. Then as we are going to get our Christmas tree, as we start going up hills, it starts sputtering every hill we hit, with the fuel filter light coming on, then going off when we go down the hills...and clearing up. We made it home and the truck seemed okay, so I went to drive it the next day and I go to drive it home from a job and it just stopped running. It seemed like it ran out of fuel, so I went got fuel and put it in and it seemed to start okay so I started home. I got to the first hill and it died, restarted it and drove the rest of the way up the hill, and drove all the way to the next hill, and so on, until I hit a hill and it did not start again. I had to have it towed because it just would not start. I changed the filter again, got it started but on the very first hill, it stalled. I got it started, and got it home, but I am afraid to drive the thing until I know what is going on. Sorry this is so long winded, I just wanted to be thorough.
sixshooter is offline
post #2 of 6 (permalink) Old 01-05-2012, 12:41 AM
Sofa King Awesome.
DarkHorse89's Avatar
Re: Truck loses power and stalls going up hills
Well, it sounds to me like you're getting some air intrusion. It could also be that the mechanical lift pump is starting to fail. Have you purged the schrader valve on the filter head to see if you've got air in the fuel? If not, do that and see. My truck did something simillar and it turned out to be the lift pump. I'm not quite sure how the hills would be affecting it though Oh well, hope this helps.
-Clint
1990 F250 Ex cab 7.3 ZF5 NA
1995 F-250 7.3 PSD ex-cab. A "few" mods.
1994 F250 Ex cab 7.3 ZF5 ats factory turbo. Now parts truck.
1975 F-250 4X4 390 + 4-speed.
1989 F250 5.8 Five Speed Dew-Eze Bale carrier.
1984 F-150 4X4 300-6, 4-speed.
1992 Mercury Grand Marquis
2000 Lincoln Towncar. Wrecked!
DarkHorse89 is offline
post #3 of 6 (permalink) Old 01-05-2012, 02:05 AM
f350dualie's Avatar
when you hit a hill you give it more throttle and the engine has a greater load which means more fuel from the lift pump
it does sound like a lift pump starting to go out
you should be able to get a lift pump for about 30 bucks (rock auto.com had one for 28.99 plus shipping)
and what is a Centurian
f350dualie is offline
post #4 of 6 (permalink) Old 01-05-2012, 03:22 AM
NMB2's Avatar
Send a message via Yahoo to NMB2
Really?
NMB2 is offline
post #5 of 6 (permalink) Old 01-05-2012, 03:47 AM
f350dualie's Avatar
never seen one before i had to google it
post #6 of 6 (permalink) Old 01-05-2012, 06:30 AM Thread Starter
I am new to these and the only thoughts we had were that the lift pump was going bad. It seemed to be the only thing that made sense because the filter was new and the idiot light for the filter keeps coming on going up hill and going off on the flat or going down hill (which I assume the light is just a pressure drop sensor) so it had to be something before the sensor....but being a newbie I didnt want to just start changing parts without going to the sources first. I will change the pump when it is above 12 degrees here. Thanks
Human Verification
