1997 powerstroke aftermarket exhaust - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 10-26-2011, 02:39 PM Thread Starter
Heartbroke Powerstroke's Avatar
I'm sure this question has been asked before... But is there any aftermarket exhaust (manifold back) that doesn't require you to smash your firewall in with a sledge hammer for installation...? Or as they say... Alter your firewall... I'm not sure Ive ever seen such a ridiculous colaboration of pancaked pipes! What was Ford thinkin? I'd like to rid of this nonsense and wake this bitch up!
Heartbroke Powerstroke is offline
post #2 of 29 (permalink) Old 10-26-2011, 03:18 PM
wrenchturner250's Avatar
Re: 1997 powerstroke aftermarket exhaust
No sir you must alter it or do a body lift
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #3 of 29 (permalink) Old 10-26-2011, 03:54 PM
94.5stroker's Avatar
I have heard of people on here not having issues due to how far the engine is set up in it's mounts, and how the cab is mounted. You might be able to slide the engine forward enough to get the dp to clear, but I am not sure on this. I just used a porta-power and moved it a bit and tired the pipe then moved it a little again and so on......
94.5 F-250 ECLB Flatbed, Rosewood Stage Ones, 3'' dp to 3'' straight, 6637 style intake, gauges, TW Tunes: (stock, high idle, economy, tow, street, extreme), boost fooler, DIY E-Fuel setup.
94.5stroker is offline
post #4 of 29 (permalink) Old 10-26-2011, 03:59 PM Thread Starter
Hmm... A body lift? Sounds like a good idea... Would I need to go a full 3" or would 2" work? Does the exhaust clear everything with the body lift installed? Or is there still going to be a passenger in my truck wondering why his shoes are melting from the pipe sticking out of my floor???
post #5 of 29 (permalink) Old 10-26-2011, 04:04 PM Thread Starter
So are the power gains worth the time and money???
post #6 of 29 (permalink) Old 10-26-2011, 04:10 PM
I would never go more then 2 in on a body lift. I fit my 3in dp with no altering the firewall.
f250towrig is offline
post #7 of 29 (permalink) Old 10-26-2011, 04:36 PM
STILL LEARNING
Bradbilt's Avatar
Not really power gains, just better exhaust flow, lowering EGTs
Bradbilt is offline
post #8 of 29 (permalink) Old 10-26-2011, 06:32 PM
OBS Stroker
Nodge's Avatar
All you really need to do is cut down, or fold over the pinch weld seam, and you'll have plenty of room. I wouldn't say I smashed my firewall. "Massaged" is a little more accurate. I use a combination of dremel, pry bars, 2x4's, baseball bat, and a 3lb hammer.
It's not that bad.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #9 of 29 (permalink) Old 10-26-2011, 10:06 PM
It wont be manifold back as there are up-pipes to the turbo, it will be a turboback exhaust, also you dont need to "smash the firewall" or use a sledge hammer. Most people use a pry bar, port-a-power, a baseball bat works great too, its not that hard of an install.
02 f250
countryboyrob is offline
post #10 of 29 (permalink) Old 10-26-2011, 10:30 PM
Just another OBS addict
rancherstroker6's Avatar
As others have mentioned, what's the big deal of smashing the firewall? It's not like you're putting a huge hole in it, as Nodge said all you're doing is bending the pinchweld on the bottom of the firewall. It's not that big of a deal once you get the stock pipe out, the pinch weld will be staring you straight in the face, and then it's straight-forward. As was mentioned above, OBS's are known to have different engine placements
(forward or back), so you may not have to alter the firewall even that much. Just make sure you do the firewall before you put the downpipe in the first time...ask me how I know .
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
Human Verification
