7.3 Head gaskets - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 04-02-2011, 05:26 AM Thread Starter
Chrisf97305's Avatar
Send a message via Yahoo to Chrisf97305
7.3 Head gaskets
I am going to remove my heads to install new valve springs and to inspect the top end of the engine.
Here is my question Which head gaskets are the best.
Ford, they want $120 each for them
International, they want $95 each
Then I went to the local parts store and asked for Fle-Pro and they were only $28 a set.
What gives, With pushing between 60 to 70 PSI of boost which head gasket do I want to run?? Don't much care how much as long as they last.
Can any one shed any light on this??
Black Magic Motorsports
1997
F350
Mods: Stage 2 Injectors, DP Tunner, Intercooler, 4" Exhaust and a Custom Filter assy.
Chrisf97305 is offline
post #2 of 24 (permalink) Old 04-02-2011, 05:34 AM
Sponsor
TerminatorEngineering's Avatar
Re: 7.3 Head gaskets
You will want Fire Rings. Call Wide Open. At 70 lbs, I doubt stock gaskets will hold. 801-233-1111.
Visit us at:
for all your Big Oil needs.
SDRCM #7
TerminatorEngineering is offline
post #3 of 24 (permalink) Old 04-02-2011, 06:24 AM Thread Starter
This year I will be wastgating it to 55 to 60psi. I may hit the 70 with laughing gas
1997
F350
post #4 of 24 (permalink) Old 04-02-2011, 08:29 AM
Demon Dually
speeddemon31176's Avatar
You better stud it and fire ring it or you are likely to launch a head right off the engine.
speeddemon31176 is offline
post #5 of 24 (permalink) Old 04-02-2011, 01:38 PM
96strokerbp's Avatar
I've run fel pro for about 3,000 miles havent had a problem, replaced head bolts and at 28 a side cant beat them.
96 f-350 7.3 RCLB
5 speed 175,000 miles, AFE Intake, 5 in. Straight Ts 6 pos chip wildman tuned, rds stage 2's, *17 hpop,38r turbo with wicked wheel
96strokerbp is offline
post #6 of 24 (permalink) Old 04-02-2011, 01:59 PM
neverkickn's Avatar
For a stock to near stock truck you are correct.
01 f250 scsb Work Truck
neverkickn is offline
post #7 of 24 (permalink) Old 04-02-2011, 04:14 PM
FYI there's absolutely no reason to pull the heads off for valve springs! Throw some H-11 studs on it and go.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #8 of 24 (permalink) Old 04-02-2011, 05:01 PM
strokeorcroak's Avatar
Id say go with the international ones.... But if you have the heads off, there is no reason not to fire ring it just to save yourself in the future
1996 with 35s
615hp/1258tq on 9/19
strokeorcroak is offline
post #9 of 24 (permalink) Old 04-02-2011, 09:15 PM Thread Starter
I know I don't have to remove the heads to install the springs. I just want to inspect everything before I start the pulling season.
1997
F350
post #10 of 24 (permalink) Old 04-02-2011, 09:39 PM
Busy Busy
Marty's Avatar
I'd say don't. Different thickness of gasket.
Agree whole heartedly.
I would not pull the heads to do this. If you have to though... use advice below.
Stock gaskets will hold as long as they are aged. However they will not hold if they are new.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
Human Verification
