unhook factory wastegate line?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 09-22-2010, 04:23 PM Thread Starter
needs more fuel
96f350psd's Avatar
im wanting to unhook my factory wastegate hose and put my boost gauge there. anyone have any pics of this being unhooked? or where its at? an what is the max boost i should see?
-Mason
96 f250 xl reg cab lwb 7.3 zf-5 3.5" straight pipe with
87 f150 xlt 302 original aod 3:55s straight pipes
90 bronco 6" lift 35s 302 aod, locked rear end
89 f150 302 aod 4x4 15x8 mb razors 33" swampers
And like paul said, a smoke tune on 90cc injectors is about as useful as dial up internet when trying to watch porn.
96f350psd is offline
post #2 of 17 (permalink) Old 09-22-2010, 05:15 PM
Re: unhook factory wastegate line??
We do not have a wastegate on the OBS trucks, so what hose are you referring to?
The boost gauge is easily connected by teeing into the MAP sensor hose. This hose runs from the passenger intake plenum up to the MAP sensor located on the passenger firewall. You must Tee into this line, not disconnect it, as it's important to have an accurate MAP sensor reading going to the PCM.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 17 (permalink) Old 09-22-2010, 05:24 PM Thread Starter
needs more fuel
96f350psd's Avatar
ok then thats the line im refering to. any special clamps or tees needed?
-Mason
post #4 of 17 (permalink) Old 09-22-2010, 05:31 PM Thread Starter
needs more fuel
96f350psd's Avatar
[IMG][/IMG]
-Mason
post #5 of 17 (permalink) Old 09-22-2010, 05:38 PM
Ticking time bomb
dont unhook that just t into it if thats not plugged into the map sensor it wont fuel
I wonder what my sig and avatar will get changed to now!!
groomzybanshe is offline
post #6 of 17 (permalink) Old 09-22-2010, 05:44 PM Thread Starter
needs more fuel
96f350psd's Avatar
ok ill see if i can get some clamps and a tee
-Mason
post #7 of 17 (permalink) Old 09-22-2010, 09:58 PM
For best results drill and tap the Y-pipe that comes off the turbo.
02 f250
countryboyrob is offline
post #8 of 17 (permalink) Old 09-22-2010, 10:18 PM
Don't EFN worry about it
Aljay's Avatar
Nor will it shift right if you have an auto trans
Tuned by T Wildman
Aljay is offline
post #9 of 17 (permalink) Old 09-22-2010, 10:20 PM
Gone Broke
Stroker96's Avatar
08 F-350 CC SB King Ranch 4x4
H&S Black Maxx 300 tune, Unlimited Intake, 6" Exhaust, Fuel Nutz wrapped with 295 Trail Grappler's
2000 F350 6spd Powerstroke For Sale!
UNLIMITED DIESEL PERFORMANCE
Stroker96 is offline
post #10 of 17 (permalink) Old 09-23-2010, 12:43 AM
What the best way to keep the metal shavings out of the the system when drilling and tapping the y-pipe?
'96 F250XL xcab SB , 3"dp , gutted cat, 6637, Stancor 902 gpr.
Otter70 is offline
Human Verification
