Want Power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-20-2017, 01:11 AM Thread Starter
Want Power
My 97 7.3 Came with 3" downtube and 4" exhaust. i put a TS 6position chip and a Tymar intake.
I want more power but the build will be a slow and steady kind of thing. where should i start?
Valdez50 is offline
post #2 of 13 (permalink) Old 04-20-2017, 01:13 AM
ZipTieologist
Re: Want Power
Fuel system, clutch/TC-VB, injectors, intercooler, hpop. Those kinds of things.
Sent from my HTC One A9 using Tapatalk
1997 Ford F250 ZF5 4x4
376k miles
D60 Swap
TS6-Diesel Innovation Tunes
Luk Clutch
Glowshift gauges (still work lol)
97fordWyatt is offline
post #3 of 13 (permalink) Old 04-20-2017, 12:34 PM
Diabolic1's Avatar
Re: Want Power
Gauges.
1997 CCSB, 7.3/E4OD
Full Force Stg 1 injectors, 3" DP, 4" exhaust, E-Fuel, 7.3 Intercooler, WW2, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #4 of 13 (permalink) Old 04-20-2017, 01:05 PM
Bugman's Avatar
Re: Want Power
If you have a automatic start saving for a rebuild.
Bugman is offline
post #5 of 13 (permalink) Old 04-20-2017, 03:14 PM
ZipTieologist
Re: Want Power
Originally Posted by Diabolic1 View Post
Gauges.
That was the first thing I ordered before I even did an intake and exhaust lol.
376k miles
D60 Swap
Luk Clutch
post #6 of 13 (permalink) Old 04-20-2017, 03:35 PM
Re: Want Power
I am about to rebuild the transmission on my 97 E40D and have been searching around. What are recommended?
Figure it can help the OP as well knowing.
Burco is offline
post #7 of 13 (permalink) Old 04-20-2017, 07:50 PM
Sponsor
Justin@DP-Tuner's Avatar
Re: Want Power
Good custom tunes can pretty much maximize the power stock injectors are capable of. Once you have done that and added an exhaust/intake, you are really looking at upgrading injectors if you want to see a significant change in power. Before doing that though, you should invest in some supporting mods. This would include an intercooler, e-fuel, etc.
Let us know if we can help you out.
Justin Bochmann
Like us on
Justin@DP-Tuner is offline
post #8 of 13 (permalink) Old 04-20-2017, 09:59 PM Thread Starter
Re: Want Power
Gauges.
I have a boost and exhaust temp gauge . i should've mentioned that earlier.
I actually have money saved up for this purpose already. what would you recommend?
I read somewhere that i can pull the intercooler off a newer Powerstroke and just figure out the plumbing and that would work. Is this true? I can turn a wrench and install with the best of them but when it comes to purchasing I'm still trying to figure out what is best and what works with what
Valdez50 is offline
post #9 of 13 (permalink) Old 04-20-2017, 10:52 PM
Sponsor
Re: Want Power
Yes, that is correct. That is how most OBS guys do it. You can find a used SD intercooler for pretty cheap.
There are also intercooler kits made specifically for the OBS trucks. Such as the Hypermax kit...
Hypermax 1994-1997 Intercooler System (This item is drop shipped from the manufacturer) - Intercoolers & Water Injection - Turbo Products - 1994.5 - 1997 F250/F350 OBS 7.3L - Ford Powerstroke
That comes with everything you need and takes the least amount of effort to install.
Justin Bochmann
Like us on
post #10 of 13 (permalink) Old 04-21-2017, 01:39 AM
Native Texan
masakimm's Avatar
Garage
Re: Want Power
Ok on the trans it depends on how much you want to spend there are many options. Some key upgrades are the forward planetary and reverse planetary they are light weight alum 4 pinion the upgraded version are steel six pinion. of course an endless array of clutch choices. There is a snap ring on the intermediate overdrive cylinder that likes to come out and ball up so they make a spiral ring upgrade to fix that problem. They make upgraded input shafts. Of course the torque converter. Like i said there's a lot of options for upgrades just depends on you budget.
95 F350 XLT SuperCab Dually
Engine Upgrades:
|Bellowed UpPipes|Stage 1 Injectors|Baby Badger Hpop|Rebuilt Turbo 360 Bearing|Custom E-Fuel|Manual to Auto Conversion
|Delete Pedestal|3" Down Pipe 4" Exhaust|Dual Tensioner and Belt|Stainless Steel HPX Crossover|Banks InterCooler
|42 Gal Rear Tank 38 Gal Front Tank
masakimm is offline
Human Verification
