Few More Mods Made. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 9Likes
post #1 of 33 (permalink) Old 03-30-2017, 05:50 PM Thread Starter
Diabolic1's Avatar
Few More Mods Made.
Just thought I would share my progress. I recently added a 7.3 IC, 1.0 Exh Housing, WW2, 360 bearing kit, and the sound and performance is fantastic! I see a reduction in loaded egt's of about 175 degrees when pulling at a steady 15 pounds of boost going up a steep incline. I use to hit 1250-1300 and now it sits steady 1050-1100 degrees turning 2200 rpm and 15#'s. I decided to flush my coolant, and add a filter. I bought Motorcraft battery cables, and finally a quick drain valve on the oil pan. Think I'm done for a while. Lots of great help from this site.
1997 CCSB, 7.3/E4OD
Full Force Stg 1 injectors, 3" DP, 4" exhaust, E-Fuel, 7.3 Intercooler, WW2, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 33 (permalink) Old 03-30-2017, 11:16 PM
Sponsor
Justin@DP-Tuner's Avatar
Re: Few More Mods Made.
Looks good!
Justin Bochmann
Like us on
Justin@DP-Tuner is offline
post #3 of 33 (permalink) Old 03-31-2017, 12:46 AM Thread Starter
Diabolic1's Avatar
Now I have to figure out how I'm going to replace the stub shaft I-joint with the shaft still in the truck.
1997 CCSB, 7.3/E4OD
post #4 of 33 (permalink) Old 03-31-2017, 01:39 PM
410customs's Avatar
ball joint press may help with that U joint
Looks awesome man, glad to hear those mods are working well
Its hard to tell from the pic, does your brake switch have the recall fuses on it?
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
SEVEN POINT THREE LEAKER
410customs is offline
post #5 of 33 (permalink) Old 03-31-2017, 01:55 PM Thread Starter
Diabolic1's Avatar
Yes it has the fuse.
1997 CCSB, 7.3/E4OD
post #6 of 33 (permalink) Old 03-31-2017, 02:15 PM
Because I can!!!
Thatchevyguy's Avatar
You've officially got my favorite ccsb that I've ever seen
97 F350 cclb
Lots of go fast parts
Dark candy apple now- twas a 7 different color project truck
5spd swap with SBC
And a 98 Chevy k1500 dd - leveled and looks pretty but is slow as hell!!
OBS FOR LIFE!!!!
Thatchevyguy is offline
post #7 of 33 (permalink) Old 03-31-2017, 02:25 PM Thread Starter
Diabolic1's Avatar
That's quite a compliment. Thank you. It's been quite a process this year and I think I've addressed every part of the truck in one way or another. I always wanted a CCSB 4x4. I procrastinated forever looking for that great deal. Once I figured out it was going to be exspensive no matter what, I went ahead and bought one. It gets more conversations started than my 93 Lightning.
1997 CCSB, 7.3/E4OD
post #8 of 33 (permalink) Old 03-31-2017, 02:26 PM Thread Starter
Diabolic1's Avatar
I want to get a hood liner and replace that stub shaft u-joint, then I'm done until something needs attention.
1997 CCSB, 7.3/E4OD
post #9 of 33 (permalink) Old 03-31-2017, 02:28 PM
410customs's Avatar
shes dang near perfect man! You should do a photo shoot of the whole truck and post it up!
post #10 of 33 (permalink) Old 03-31-2017, 04:04 PM
79jasper's Avatar
Hood liner? What's that? Lol
I take them out on everything.
Then foil/aluminum backed stuff would look good.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
Human Verification
