So I have a 1994.5 7.3 PowerStroke, the turbo was directed straight into the motor, My buddy was taking his turbo, intercooler and everything off he's 2000, to go bigger. so i bought it all of him. i finally had the time to install it all. I took everything in the Vally out, rebuilt the 1.00 Ar turbo. before putting it all back together, since I had everything out of the way, I replaced the HPOP, with a MB Diesel 17* HPOP, and CNC fabrication HPO lines W/ HDX Cross over. Replaced the 2" stock Plenums with the 2000 3" plenums, reinstalled the lift pump in fuel bowl, bolted up the new turbo Pedestal had to mock up the new Exhaust up pipes and Y Connector, got it lined up to the new turbo. had to clamp closed the top Blow off valve(no room for it under the Firewall). was able to adapt the waste gate to my 3" straight down pipe. Had to rotate the fuel bowl a little to allow enough room for the spider(it still a very tight fit, Even after plugging and grinding the 3 front holes Flat). Mounted the new intercooler, ran the pipes,(had to flip the riverside to make it able to fit around the power steering lines.
Final was able to start her up again, she sounded fine, when to go take her for a test drive and NO POWER, can only get to about 55Mph, 4 gear is all she wants, turbo is spinning freely but not hearing it boost at all. Will only run at about 2,500 Rpm. Please help. Im still running OBD 1 and the ford dealership won't even help me. At full throttle it blow white smoke, no power on the road. Don't know what could be wrong, No check engine light. My EOT(engine oil temp just behind the ) sensor has been broken as long as I've had the truck.
