MAP Sensor Disconnected - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 04-07-2009, 10:31 PM Thread Starter
Senior Veteran Member
Centxdiesel's Avatar
Garage
Why does my truck have more power on take off with the MAP sensor disconnected? Do I have another problem causing it to have low power when starting off ? No CEL on until MAP sensor disconnected.
Centxdiesel
1997 F250 XL SC, 445HP 886TQ,
30% nozzle Hybrids from Nate@
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #2 of 23 (permalink) Old 04-07-2009, 10:47 PM
Tater for President!
Re: MAP Sensor Disconnected
It'll throw a CEL with the MAP disconnected...sounds like you have a bad MAP sensor...Might try replacing it with a known good one. Is it a real dog with the sensor plugged it?
#31
1997 F-250 - SCSB - ZF-5, 4x4, 4.10, 17* HPOP, Tymar Intake, TWildman Tunes, SD IC, 4" Straight Exhaust, Dana 60 w/ 3.5" RSK and SD Springs all around on 35" BFG A/Ts - SOLD
2009 - 6.4L - Crew Cab/Long Bed - FX4 - 4" Pure Performance X-Factor Lift - 325/60/20 Duratracs -- FOR SALE
2014 - 6.7L - Crew Cab/Long Bed - Lariat 4x4 - Stock
PSDfreak is offline
post #3 of 23 (permalink) Old 04-08-2009, 12:05 PM Thread Starter
Garage
I should have said, I replaced the original MAP sensor. May run a tad bit better, but definatelt runs much better off the line with it disconnected.
Centxdiesel
post #4 of 23 (permalink) Old 04-08-2009, 12:24 PM
Cummins Power
mech2161's Avatar
When disconnected the pcm uses a default value. That value is higher than it would be if connected.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #5 of 23 (permalink) Old 04-08-2009, 01:05 PM
Snake Oil Salesman
mattr66's Avatar
If it is the stock tuning the disconnected sensor allows for more fuel before the turbo spools. You are simply removing your smoke control in the tuning by unplugging the map sensor wires.
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #6 of 23 (permalink) Old 04-08-2009, 02:56 PM Thread Starter
Garage
Ahhh, thanks for the info. Yes still stock tuning. Will it do any harm leaving the MAP unplugged?
Centxdiesel
post #7 of 23 (permalink) Old 04-08-2009, 04:04 PM
Snake Oil Salesman
mattr66's Avatar
Just the penguins and other wildlife......lol
Matt Robinson
mattr66 is offline
post #8 of 23 (permalink) Old 04-08-2009, 04:21 PM
Cummins Power
mech2161's Avatar
It will not have as much top end power. It needs to see boost to add fuel.
Kevin
mech2161 is offline
post #9 of 23 (permalink) Old 04-08-2009, 04:26 PM
Snake Oil Salesman
mattr66's Avatar
The OBS substitues a value in there and pretty much gives max fuel from what I have seen....
Matt Robinson
mattr66 is offline
post #10 of 23 (permalink) Old 04-08-2009, 04:28 PM
Cummins Power
mech2161's Avatar
Across the board when connected?
Kevin
mech2161 is offline
Human Verification
