shimming fuel pressure regulator - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-06-2009, 09:12 PM Thread Starter
oilfield trash
big adam's Avatar
any ideas on how to shim the fuel pressure regulator on my obs? i have heard of several ways, but which is the best way?
97 F350 cc lb 2wd 4" diy exhaust, diy intake, bully dog 6pos, ranch hand front and back
big adam is offline
post #2 of 13 (permalink) Old 03-06-2009, 10:46 PM
secondarychaos's Avatar
Re: shimming fuel pressure regulator
Have you checked your pressure to make sure you need to first? that's pretty important.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #3 of 13 (permalink) Old 03-06-2009, 10:49 PM
Just another OBS addict
rancherstroker6's Avatar
Yea, I was wondering the same thing...secondarychaos, you only do it if you have pressure problems?I thought I heard somewhere that you can do it for more power
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
post #4 of 13 (permalink) Old 03-06-2009, 10:53 PM
The Fireman
big_stroker's Avatar
You don't need to worry about fuel pressure unless you are having problems with it anyway. And even then I would recommend a Regulated Return and adjust the fuel pressure this way.
big_stroker is offline
post #5 of 13 (permalink) Old 03-06-2009, 11:26 PM
The only good reason to do the FPR shim IMO is to gain back some of the power lost over the years from wear and tear on the pump.
I suppose you might gain a few ponies from doing it on a truck with a decent pump, but then you're putting even more wear on it.
the extra pressure will only help you to a point anyway.
Dan
post #6 of 13 (permalink) Old 03-06-2009, 11:38 PM
<----Colin Banks
mattymx's Avatar
Go to a Ford dealer and buy a California FPR kit. Safest way to bump pressure on a stock system.
mattymx is offline
post #7 of 13 (permalink) Old 03-06-2009, 11:51 PM
robp823's Avatar
all it is a spring that gets weak over time i agree just get a new fpr or the cally kit
robp823 is offline
post #8 of 13 (permalink) Old 03-07-2009, 01:07 AM
So if my truck is already California truck, does it have this kit?
post #9 of 13 (permalink) Old 03-07-2009, 01:18 AM
Terminator Nation
All california trucks have the kit already. If you have priced the kit then you know why people use the BB. The kit may no longer be availiable anyway.
old man dave is offline
post #10 of 13 (permalink) Old 03-07-2009, 03:24 AM
<----Colin Banks
mattymx's Avatar
They will not. The higher pressure FPR was brought about when the CA. models went to AB split shot injectors in mid 1996. So with rancherstroker6's truck being a 95, it will not have the high pressure FPR.
mattymx is offline
Human Verification
