Do I need a new exhaust? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-23-2012, 02:53 AM Thread Starter
Currently I'm running a 96 F350 with tymar intake, SD compressor wheel, and aftermarket 3.5 downpipe, gutted cat, and a TS 6 pos chip. How much would I gain by going with a 4 inch exhaust with muffler and cat delete. Just wondering if it is worth the money. The EGT's haven't gotten above 1200 degrees, with the hammer down pulling up a hill.
96 F350 CCLB 4X4 7.3
CFiss is offline
post #2 of 12 (permalink) Old 04-23-2012, 03:02 AM
19stroker97's Avatar
Re: Do I need a new exhaust?
If by sd compressor wheel you mean wicked wheel, there is no performance there, our trucks came stock with a wicked wheel. As for the exhaust you wouldnt gain much since you already have a dp and no cat. It will sound better with a 4 inch exhaust though.
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #3 of 12 (permalink) Old 04-23-2012, 03:28 AM
Terminator Nation
A broader torque curve across the powerband mainly. I actually pulled 400hp through the stock 3.5" muffler but the power was more peaky than with the true 4" I installed later. Use a muffler, straight pipes are just for noise value; the cat and EBPV are the big restrictions after the downpipe. The 4" truck mufflers are a straight through design with very little restriction. The stock 3.5" muffler is also a straight through design.
old man dave is offline
post #4 of 12 (permalink) Old 04-23-2012, 01:00 PM Thread Starter
By SD wheel I meant just that, not the wicked wheel.
CFiss is offline
post #5 of 12 (permalink) Old 04-23-2012, 10:35 PM
Well thats worse than the stock obs wheel.
-Tyler-
post #6 of 12 (permalink) Old 04-24-2012, 03:27 AM
95powersmoker's Avatar
Like old man rivers said... 3.5 is plenty if you don't have huge expensive build plans in the future... The only thing you'll gain is a little change in sound... It's not "needed" with your one mod...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #7 of 12 (permalink) Old 04-25-2012, 12:01 AM Thread Starter
Thanks guys, appreciate the info. So what would you guys consider the next mod should be?
CFiss is offline
post #8 of 12 (permalink) Old 04-25-2012, 12:22 AM
STILL LEARNING
Bradbilt's Avatar
Depends what you are looking to do. But I dont understand why you put a "SD" wheel in your truck?
Bradbilt is offline
post #9 of 12 (permalink) Old 04-25-2012, 12:30 AM
oil burner
tughill283's Avatar
nothing really makes a big difference till you get rid of the whimpy stock injectors in an obs 7.3
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #10 of 12 (permalink) Old 04-25-2012, 02:31 AM
Daily Stroker
DieselFreak92's Avatar
Next mod would be gauges, trans upgrades, then injectors.
1997
F250 Day Cab Long Bed 4x4 E4OD
- 04 axles - TS chip - diamond eye 5 inch - DIY intake -
- T500 - Stillwell built trans -
DieselFreak92 is offline
Human Verification
