timing adjustment on a psd?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 11-22-2011, 08:57 AM Thread Starter
needs more fuel
96f350psd's Avatar
seen a guy with a 2000 psd the other day. bellowed smoke like there was no tommarow. he said only thing done to was a 6 pos chip and he had the timing adjusted to 19* or something. it blowed so much smoke it would run out of fuel reving it up in park. now i dont want near that much smoke! i just want the power that thing had! it would roast the tires off of it on the highest setting. he said it had stock injectors but it couldnt have! im gonna call the number he gave me to the people who tuned it and see what they can tell me.
-Mason
96 f250 xl reg cab lwb 7.3 zf-5 3.5" straight pipe with
87 f150 xlt 302 original aod 3:55s straight pipes
90 bronco 6" lift 35s 302 aod, locked rear end
89 f150 302 aod 4x4 15x8 mb razors 33" swampers
And like paul said, a smoke tune on 90cc injectors is about as useful as dial up internet when trying to watch porn.
96f350psd is offline
post #2 of 15 (permalink) Old 11-22-2011, 01:31 PM
One Stroke @ a Time
jsnyder7.3's Avatar
Re: timing adjustment on a psd??
Sounds unlikely that a chip is the only thing he had! The only way to adjust the timing on a PSD is through programming and should ONLY be done by someone who really knows what their doing! It is very easy to melt pistons, valves, turbos, other expensive sh*t if you don't know what your doing! As far as melting the tires, that's torq and any PSD should boil the tires if powerbreaked.
Just my $.02
97 F350 CCLB 4x4
a bunch of costly things and some bloody knuckles, but a lot of fun to drive!
"Loaded like a freight car, driven like a stock car!"
jsnyder7.3 is offline
post #3 of 15 (permalink) Old 11-22-2011, 02:24 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
With the right (wrong) tunes, a 2000 can smoke it's ass off. And that guy might have had his tuner turn his timing down or up, but that's the only way.
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #4 of 15 (permalink) Old 11-22-2011, 11:45 PM Thread Starter
needs more fuel
96f350psd's Avatar
thanks guys. no being powerbreaked here. from a dead stop WOT this thing would f*cking scoot! didnt have a chance to call today but i will tommarow. how is all the smoke possible with stock injectors?
-Mason
post #5 of 15 (permalink) Old 11-22-2011, 11:56 PM
jaybuller's Avatar
his tuner just through all the fuel in at low boost levels or no boost
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #6 of 15 (permalink) Old 11-23-2011, 12:27 AM Thread Starter
needs more fuel
96f350psd's Avatar
but it smoked like that untill you let off of it at 100 mph
-Mason
post #7 of 15 (permalink) Old 11-23-2011, 12:38 AM
95powersmoker's Avatar
who cares if it smoked?
Sounds like your idol is a real smart guy, he can afford the worlds fastest smoke belching diesel.... cool...
He should invest in a fricken turbo to clean up that smoke.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #8 of 15 (permalink) Old 11-23-2011, 05:27 AM Thread Starter
needs more fuel
96f350psd's Avatar
im just trying to figure out how he made it that quick. i dont give 2 ####s about all that smoke. apperently the fuel was part of it! that was a reply to the earlier post about no boost or low boost is when it was dumping the fuel
-Mason
post #9 of 15 (permalink) Old 11-23-2011, 01:55 PM
One Stroke @ a Time
jsnyder7.3's Avatar
If its as fast as you're saying and smoking the way you're describing I still say its not stock injectors. They won't smoke like that under load unless there is low boost, and if that's case it wouldn't be fast. I don't know that I've ever met a racer or builder that is willing to tell someone they just met everything they've done to the motor. With enough fuel and air anything is possible. Speed cost money, how fast you wanna go? Call most any of the sponsors on here and they can set you up with a package that will pop the tires and run 11's if that's what you want!
97 F350 CCLB 4x4
post #10 of 15 (permalink) Old 11-23-2011, 02:21 PM Thread Starter
needs more fuel
96f350psd's Avatar
I just want the take off.he had. I couldn't believe he let me.drive it. I thought the tranny was slipping but when we got back there were 2 long a$$ black marks were I.thought it was slipping
-Mason
Human Verification
