6637 mod: what can it support? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 09-09-2011, 12:46 AM Thread Starter
Can a simple 6637 filter support 500rwhp, or is it not gonna be able to flow enough air?
I ask because I can get the filter locally for $23 but if it wont work for my end goals i'll go straight to an intake system that can
nick112207 is offline
post #2 of 20 (permalink) Old 09-09-2011, 12:55 AM
Patrick Feeley's Avatar
Re: 6637 mod: what can it support?
I'll take a stab at it and say yes (depending on how you plumb it ... no PVC fittings!). The Donadson filter used in the Tymar setup can flow a lot of air. JMO though. Cheers!
Patrick Feeley is offline
post #3 of 20 (permalink) Old 09-09-2011, 01:46 AM
NevrKnow's Avatar
There's not much more you can do to flow more air except...NO filter.....and you know the answer to that.....NO
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
post #4 of 20 (permalink) Old 09-09-2011, 02:22 AM
mxredneck's Avatar
Take a deep breath through a 6637. Feels like there is no restriction at all, like you were breathing normal... I had to try it when I got mine
1996 F-350 CCLB dually, 4.10, 235/85R-16, ZF5, Tymar intake, Alabama Flowmaster, Isspro gauges, TS chip, Tightwad Mod
mxredneck is offline
post #5 of 20 (permalink) Old 09-09-2011, 02:49 AM Thread Starter
Anyone know the specs of the 6637 filter?
I'm rather curious why its so much cheaper than the BHAF dodge guys use (napa 2790). Its half what the dodge filter is
post #6 of 20 (permalink) Old 09-09-2011, 03:15 AM Thread Starter
Actually here is a more important question.
How close does the 6637 come to touching the hood/other surrounding objects?
Because the 2790 filter is 1/2" shorter, but 2" fatter, and according to fleetfilter flows 680cfm vs 400 for the 6637
Both have the same 4" outlet
post #7 of 20 (permalink) Old 09-09-2011, 03:49 AM
Running at last...
powerstroke cowboy's Avatar
I like the looks and sound of the 2790. But I will have to go out and look, to see if it will fit in the same spot as a 6637.
That is a good increase in flow over the 6637 680 vs 425. That is a good increase..
On Edit: Here it is........Wix 42790 & Napa 2790 Air Filter: FleetFilter Secure Online Store
And for comparision the 6637.............Wix 42790 & Napa 2790 Air Filter: FleetFilter Secure Online Store
97 CCLB 4x4 ZF6 99@15.7
powerstroke cowboy is offline
post #8 of 20 (permalink) Old 09-09-2011, 05:20 AM
I don't think the other one will fit where the 6637 would go. Even if the hood closes, the larger diameter will probably be against something and restrict the flow (and negate any flow advantages). Cheers!
post #9 of 20 (permalink) Old 09-09-2011, 05:21 AM
tonka350's Avatar
I might just have to replace my 6637 soon than....I'm wanting to run a custom intake like the ATS Great White truck anyway.
Chad
00 F350, 08 clone, 3" cowl hood,billet grilles, 15" lift, 40" SS M16'S, 24X12 Rockstars, 2% tint, EBPV Delete, 4" duals w/7" tips, 6637 intake, WW, CCV Mod, PHP 80,120 race,140 Extreme, stage 1 single shots, 6.0 I/C
Chad
tonka350 is offline
post #10 of 20 (permalink) Old 09-09-2011, 09:13 PM Thread Starter
I imagine if anything this would at least help with EGT's if you could fit it
Human Verification
