best 7.3 turbo upgrade? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 71 (permalink) Old 09-06-2011, 05:48 AM Thread Starter
hey guys i was wondering what your opinion is on a turbo upgrade ive got a 94 obs 7.3 powerstroke stock injectors all thats been done is intake,exhaust and a ts tuner anyways id like more boost if possible and a faster turbo spool up any tips?
94 Powerstroke, 3 inch lift, 3"DP 4" straight pipe to 5" in bed T then to 6" Ausie stacks, DIY intake large Baldwin air filter , Ts 6 position chip custom tunes,3:54 rear end 5 speed trans Rollin on 35" procomp extreme terrains
bigred94 is offline
post #2 of 71 (permalink) Old 09-06-2011, 07:20 AM
Jjona5's Avatar
Send a message via AIM to Jjona5
Re: best 7.3 turbo upgrade?
get some stage 1 injectors.
1995 4 door dually Murdered out - 5 inch exhaust - down pipe - TS Chip with Tunes by Cale - 5 speed - Banks Pipe Kit and 7.3l aluminum end intercooler - Adrenaline HPOP - D66 - Rosewood Stage II(160/80) injectors, Gutted EBPV - Blank Ped - EGT Gauge - Boost Gauge - Homebrew Regulated Return E-Fuel
Looking for a Single Cab long bed OBS 4x4
Jjona5 is offline
post #3 of 71 (permalink) Old 09-06-2011, 12:17 PM
Heath
rollingthunder's Avatar
If your planning on staying with the stock sticks I would rebuild your stock turbo and pout a 1.0a\r housing on it. Spools up much faster off the line.
If your planning on larger injectors (Stage 1 or 2) then go with beans D-66. Its a drop in turbo.
Any bigger on injectors than you will need a custom mount or hyper max mount kit and your choice of some nice turbos--but you will need some $$$$$
2005 250 crewcab king ranch
arps, egr delete,coolant and oil bypass filters
4" turbo back MBRP
A-1000 fuel w\Reg return
Warrne 175\30's
rollingthunder is offline
post #4 of 71 (permalink) Old 09-07-2011, 04:22 AM
OBS junkie
Cat_Rebel's Avatar
Intercooling the stock charger will do a lot.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 71 (permalink) Old 09-07-2011, 05:25 AM
wrenchturner250's Avatar
Ic and a 1.0 if your not gonna go any bigger than stage 1s! I ran my 2s2s with the stock turbo for aawhile spooled great no really problems ither than being wore out lol its all about plans for your truck. I did the t4 mount because I plan on making my truck a puller one day. So the custom mount was a better option! There aren't many ways to gain boost with out fuel!
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #6 of 71 (permalink) Old 09-07-2011, 11:08 AM
I do a lot of towing with my truck (it's my work truck/personal truck) and I ordered the 1.0 turbine housing from Beans. I did this because I hear that it allows the turbo to boost in a lower RPM range, which I like for my towing situation. I don't like reving my truck to 3000 rpm when towing, thats just silly. So hopefully this turbine housing will lower the boost range down to somewhere that I normally use while towing.
But these guys are right, injectors=more fuel=faster/higher boost.
So you said you wanted fast spool up? Get the 1.0 turbine housing if you are NOT getting bigger injectors
More boost? Then get bigger injectors, reburn the TS chip (to match the new injectors) and stay with the stock turbine housing.
Here's the link for the housing I ordered. Should be delivered today actually.
Beans Diesel Performance - 94-97 Power Stroke 1.0 Quick Spool Turbo Housing (Powered by CubeCart)
94.5' XL F-350 cab chassis. Reg cab. Eby flatbed. 6637 intake, Tymar 3-4 dp, dual s.s. 6inch stacks, gauges (boost, pyro), cheap wad fpr mod w/ gauge, T-500, Rosewood stage II's 160cc/80%, dual superduty E-pumps, 6.0L intercooler, 3" plenums, 1.0 A/R housing, PHP 6 pos chip and user installed A/C, Gen II whicked wheel.
393 HP, 708TQ
King7765 is offline
post #7 of 71 (permalink) Old 10-02-2011, 05:46 AM Thread Starter
so king7765 how are you liking that new turbo housing? my thing is i wanna get rid of the excessive black smoke yeah it looks cool but thats money going out the tail pipe and when i tow i dont really start boosting unless im at least at 2,000 rpms so what im trying to aim for is faster spool up i think the housing gives more boost? and better mileage i love the truck but im afraid to drive it cause my mileage is not so great its funny these turbo's dont boost just cruising down the highway however my 6.9 IDI would be making a constant 5 psi of boost going down the freeway and that truck would give me 22.5 mpg
bigred94 is offline
post #8 of 71 (permalink) Old 10-02-2011, 06:08 AM
LawnRanger's Avatar
'96 F250 XLT CC SB 7.3L 4X4 -
Full Force Stage 1 injectors
3" dp / 4" exhaust w/delete -
TS 6 position chip -
Tymar intake -
Buck Stop front bumper / J&J Ent. Stainless rear bumper -
Air LIft airbags -
D60
4" BDS lift w/35' BFG AT's on 16" ProComp Xtreem Alloys -
'96 F350 RC LB 7.3L 4X4 -
33" MT -
Hiniker 8' C-Plow
LawnRanger is offline
post #9 of 71 (permalink) Old 10-02-2011, 06:16 AM
Davey B
davey99ps's Avatar
In the obs trucks, its hard to beat Beans d66. It's affordable, a drop in replacement, and will support some respectable hp #s. If your gonna run big sticks with it, live tuning is almost a must, but Johnathan has a few trucks close to or over 500hp with it. I was gonna go with the d66 until I stumbled into a great deal on an h2e, otherwise I'd be running 1 myself.
95 CCLB- 238/100s, H2E, termy t500, wipe out pushrods, comp 910s, mbrp exhaust, bdp tunes, and 8" lift
99 ex cab - Rolled 3/10/10
davey99ps is offline
post #10 of 71 (permalink) Old 10-02-2011, 04:04 PM
I'm still waiting for the turbine housing and gutted EBPV housing to come back from getting Ceramic coated. Been 3 freakin weeks now! I hope they get it done soon, I'm getting bored waiting.
After its in... I'll chime back in with my thoughts.
393 HP, 708TQ
King7765 is offline
Human Verification
