intercooler-vs-non intercooled boosts? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 08-28-2011, 12:30 AM Thread Starter
jonnylu
eastcoastevolutionjl's Avatar
Exclamation intercooler-vs-non intercooled boosts?
hello, just curious to what a normal boost psi should be on an intercooled obs. mods in sig.... well finallly finished my intercooler install today.7.3 alluminum cooler. had 40 psi boost with out cooler.now iam only hitting 25-28psi and dropped 200 degrees @ wot.. from 1400 to 1200 degrees which seems great, but the boosts 12 psi lost seems huge... never mine the turbo lag.. thanks jonathan
96 f-250 cc sb centurion 7.3l ,ts 6 pos chip,swamps tunes,rosewood stg.1inj.,sd7.3intercooler,tymar,tc 6'sus.lift,procomp6"rear leafs,cust trac bars,s.s mbrp straight exhaust,3gauge pod trans,boost,pyro,2nd ats trans/torque conv.,comdr lock up cont.,35x18 toyo m/t,,adrenaline hpop.detroit true trac,bdp idm,bdp electric fuel
eastcoastevolutionjl is offline
post #2 of 26 (permalink) Old 08-28-2011, 05:45 AM
Jjona5's Avatar
Send a message via AIM to Jjona5
Re: intercooler-vs-non intercooled boosts?
I lost quite a bit of boost on my truck also. I never could find any leaks either.
1995 4 door dually Murdered out - 5 inch exhaust - down pipe - TS Chip with Tunes by Cale - 5 speed - Banks Pipe Kit and 7.3l aluminum end intercooler - Adrenaline HPOP - D66 - Rosewood Stage II(160/80) injectors, Gutted EBPV - Blank Ped - EGT Gauge - Boost Gauge - Homebrew Regulated Return E-Fuel
Looking for a Single Cab long bed OBS 4x4
Jjona5 is offline
post #3 of 26 (permalink) Old 08-28-2011, 10:38 PM Thread Starter
jonnylu
yeah i checked for leaks & all seems tight too. thinking about disconnecting it but leaving cooler in for when i go to hybrids+turbo. At least the install is done and ready. might i say install came out very nice,but very tight with my minute mount push plates.... any input / advise would be helpful. thanks again.
post #4 of 26 (permalink) Old 08-30-2011, 05:20 AM
Boost pressure is not the issue really it's cooler air charge and lower egts. You (iirc) drop a couple pounds across the IC. Lower boost is compensated via cooler charge so at the end of the day generally I think it's a wash. Benefit is cooler egts which means you can put more fuel to it.... :)
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, SRK, SD springs front/rear, 145 litre rear tank (now ZF-5
White / Silver 96 F250 4x2, SCSB E4OD, 4:10 stock for now mods to install: D60, engine stuff.
White VW '15 Jetta 6MT Sport Suspension TDi
JCart is offline
post #5 of 26 (permalink) Old 08-30-2011, 06:04 AM
OBS junkie
Cat_Rebel's Avatar
Less boost - lower egts - more power - more air..... Are you complaining?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 26 (permalink) Old 08-30-2011, 09:23 PM Thread Starter
jonnylu
well i guess im used to having 40psi boost right there all the time w/no lag.i understand with what you guys are saying. i will do some testing @ the track in a couple of weeks/dyno. as for now disconnected it,150 degrees doesnt seem like enough to sacrifice 15lbs of boost....@ this stage of my build with stg 1 injectors. thanks
post #7 of 26 (permalink) Old 08-31-2011, 04:53 AM
Empty Wallet
96bullhauler's Avatar
Mine went from 35psi to 25psi per the gauge. I was referencing boost directly off the factory Y pipe, now im going off the map sensor line. i just figured it was a bad reference, because the truck wasnt any slower after the IC.
96bullhauler is offline
post #8 of 26 (permalink) Old 08-31-2011, 01:11 PM Thread Starter
jonnylu
i have mine off map sensor line also,but definately feels way slower..ill try to post #'s in a couple of weeks..thanks
post #9 of 26 (permalink) Old 08-31-2011, 11:52 PM
Empty Wallet
Are you going to do a couple pulls without IC, then with? Im curious to see the difference.
post #10 of 26 (permalink) Old 09-01-2011, 03:38 AM Thread Starter
jonnylu
yes exactaly,curious to see the #'s too..
Human Verification
