fan clutch removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-03-2011, 09:38 PM Thread Starter
Coueshunter's Avatar
fan clutch removal
Has anyone tried to change their water pump out and found that there fan clutch to pulley bolts are to close to get a wrench in between there? I removed the serpentine belt but cannot get a wrench on the fan nut without interference to the pulley bolts. ALmost like the pulley bolts have to come out first.
Any ideas?
Back the Blue BUILD THREAD
POWERSTROKENATION-
Facebook-
Coueshunter is offline
post #2 of 3 (permalink) Old 03-03-2011, 09:52 PM
excavator's Avatar
Re: fan clutch removal
I fabbed up this wrench and hit it with big hammer while someone holds tension on the serpentine belt. The fan clutch nut has to be taken off and then I raise the shroud and fan at same time after inserting cardboard against radiator
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
post #3 of 3 (permalink) Old 03-04-2011, 01:50 AM Thread Starter
Found a fan clutch removal tool, works great!
Thanks
POWERSTROKENATION-
Facebook-
Human Verification
