no wait to start light - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 11-28-2010, 04:19 PM Thread Starter
I parked my truck a week ago and went to crank it and wont start. The wait to start light wont come unless you put a jumper wire across the relay. Ive unpluged the heater have no blown fuses any thingelse I should check?
BPR83 is offline
post #2 of 20 (permalink) Old 11-28-2010, 04:46 PM
JFURNER77
JFURNER77's Avatar
Re: no wait to start light
Search the forumn for info to repair your GP system. There is plenty info available. Start with the GP relay and GP's. Then check your UVCH and engine harness. Good luck
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #3 of 20 (permalink) Old 11-28-2010, 05:10 PM
Busted Knuckles
PSDEng's Avatar
Powerstroke Nation
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #4 of 20 (permalink) Old 11-28-2010, 09:13 PM
<-Friends bike
If you are correct on the heater & no blown fuses .Do you have a chip that may have come loose ? If not , no WTS points to a bad PCM You may need to check the small relays in the distribution box , you can use the horn to test them all ...
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
post #5 of 20 (permalink) Old 11-29-2010, 01:21 AM Thread Starter
No chips or bad relays,guess that leaves the pcm. Where can I get a used one from? trying to fix this truck to sell cause i bought a new one.
BPR83 is offline
post #6 of 20 (permalink) Old 11-29-2010, 02:54 PM
<-Friends bike
I got one for $50.00 on Car-part.com ....
Rick....
post #7 of 20 (permalink) Old 11-29-2010, 11:30 PM
Are you SURE Fuse #22 under the hood is good? Do you have power on the red/light green wire that goes to the glow plug relay? That should be powered when the key is on.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #8 of 20 (permalink) Old 11-30-2010, 02:23 AM
Needing Carbon Credits
05 F350 FX4 - Deleted and Exhausted
jmontes is offline
post #9 of 20 (permalink) Old 11-30-2010, 10:22 PM Thread Starter
Thanks guys for the help. I think Ill change the pcm and see if that works. To the above post yes im getting power to the glow plug relay. I can put a jumper wire from the small post to the big post towards the front and the truck will start and run as long as I hold the wires on.
BPR83 is offline
post #10 of 20 (permalink) Old 11-30-2010, 10:29 PM
WAIT!!! If your truck is running with your jumper, the PCM is fine.
This sounds exactly like Fuse #22 is bad and your PCM is fine. By jumping from the small to the big post, you are powering the PCM--effectively replacing Fuse #22 with a jumper.
So, one more time. With the key on, put a meter or a 12volt light on the red/light green wire on the GPR (and the other terminal of the meter or light to the battery ground). I don't mean power to the BIG wires on the GPR, I specifically mean power on the little red/light green.
Do you have power there, yes or no? Without your jumper.
Let me explain the circuit here. Fuse #22 provides power with the key on to several circuits. It supplies the fuel heater; it powers the PCM, and it provides power to one side of the solenoid on the GPR. All of these wires are red/light green and they all connect eventually at Fuse #22.
Human Verification
