IPR O-Ring replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-24-2010, 06:43 AM Thread Starter
Learner
94strokeher's Avatar
I need to replace my IPR O-Rings in my 94 powerstroke and dont know where to start. Is this fairly easy to do? Help!
94strokeher is offline
post #2 of 9 (permalink) Old 10-24-2010, 04:49 PM
blageurt's Avatar
Re: IPR O-Ring replacement
This should explain it a little ...http://cw-diesel.com/LuxSite/IPRInfo.htm
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 9 (permalink) Old 10-24-2010, 04:56 PM
Patrick Feeley's Avatar
Here's a procedure for it from way back (from Coach Davis for those who remember him on TDS in the old days):
Injection Pressure Regulator Removal and Replacement by Coach Davis
I've been having a slight problem with my truck not wanting to idle very smooth especially when hot and the more miles the oil gets on it, the worse it would idle. With the engine cold it would idle pretty smooth, but hot, it had somewhat of a shake to it. When I purchased this truck, the oil had been in a little too long on this ONE and only ONE oil change and because the HEUI system is so sensitive to clean oil that I probably was going to have to change some of the components to remedy the idle/flutter problem.
I purchased a new IPR a few months ago and was trying to get enough miles on the oil before I changed it so I could ensure some of the characteristics that changed were not because of "NEW" oil. New oil will always make a Powerstroke run a little better than oil that has 3000 miles on it. I wanted to make sure I installed the IPR with the 3000 mile oil.
The Procedure:
I removed the plug on the top of the high pressure oil reservoir and took my tried and true turkey baister (equipped with a rubber fuel line and then steel brake line attached to the rubber fuel line so I could get through the small hole and go to the bottom of the reservoir to extract ALL the oil), and proceeded to extract all the oil out of the reservoir which took some time, but ended up getting a full quart out of it. Draining this HP reservoir really saved a big time mess!!
Next I drained my fuel filter bowl and loosened the lid to ensure all the diesel would be able to drain, then removed my intake "Y", stuffed shop rags in the ports and proceeded to loosen all the hoses and wiring harness associated with the fuel filter housing/IPR. I then removed the two bolts holding the fuel filter housing on the engine and lifted the housing up and out of the valley of the engine.
I then removed the cheap nut holding the IPR solenoid on and slid the solenoid off. I then took a deep socket and slowly removed the IPR.
I then cleaned around where the IPR was with a lint free cloth to ensure the new o-ring wouldn't be damaged by dirt/trash upon seating. I then coated the NEW IPR o-rings etc. with new engine oil and replaced it back into its respected provision. I then reinstalled the IPR solenoid and tightened the cheap nut ensuring I had the wiring harness connector turned in the correct direction.
I then took carburetor cleaner and sprayed the valley where a little diesel and a small amount of oil had spilled. I cleaned the entire valley and then reinstalled everything previously removed.
I then took a small funnel and poured exactly 1 quart of new oil back into the HP oil reservoir and re-installed the plug.
After the engine turned over a few more times than usual it cranked. After warming the engine up, I then proceeded to the highway where I ran locked out of OD for about 5 miles at 3200 rpm's to eliminate all the air from the HP oil system.
The only thing that I've done differently is I simply removed the plug from the top of the HPOP reservoir and used a mightyvac to suck out the oil (that way I didn't have to reseal the HPOP reservoir top). I hope that helps! Cheers!
Patrick Feeley is offline
post #4 of 9 (permalink) Old 10-24-2010, 11:04 PM Thread Starter
Learner
Thanks guys! Im going to order the o- rings tomorrow and get em in asap. Wish i would have done this a few months ago while i had the fuel bowl out to do the fuel pump Oh well tho.
post #5 of 9 (permalink) Old 10-25-2010, 02:02 AM
When you shop for the O-ring kit pays to look around. Was quoted at the Ford Stealership $108.00...ahem said thanks but just can't do it for that...sorry. International was $25.00 for the exact same thing only in an IH parts bag...I would never have guested the price differential....holy...
jrc
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, SRK, SD springs front/rear, 145 litre rear tank (now ZF-5
White / Silver 96 F250 4x2, SCSB E4OD, 4:10 stock for now mods to install: D60, engine stuff.
White VW '15 Jetta 6MT Sport Suspension TDi
JCart is offline
post #6 of 9 (permalink) Old 10-25-2010, 11:27 PM Thread Starter
Learner
I found them on ebay for $13.99. My brother in law works at napa so i think iam going to contact him. He did his in his 95 and i believe he paid around $15.
$108 for a few o-rings? are you serious?
post #7 of 9 (permalink) Old 11-03-2011, 12:39 AM
95smoker's Avatar
I was having the warm start issue also. I replaced the IPR orings and it is starting fine now. The issue is, it loping a little at idle. I didnt take the IPR apart, just put the new orings on and reinstalled. I checked the reservoir and it is to the top with oil. Any suggestions? i have run it about 15 miles on short trips hoping to clear up any air in the HP oil system. its starting to worry me.
thanks
95' 115k miles original, 4in straight pipe, LUK clutch/flywheel, S&B intake, TS 6-pos chip, SD starter, smoked dodge clearence lights, 03' intercooler, 3in lift, 35" Toyo MTs, SVO kit. Soon to come: 5" RSK w/ SD springs, rear disc conversion, costom front end replacement, Dodge tow mirriors, crystal lights and HIDs, and hopefully injectors someday
95smoker is offline
post #8 of 9 (permalink) Old 11-03-2011, 12:47 AM
15 miles isnt enough 40-50 is good
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
BlindViper is offline
post #9 of 9 (permalink) Old 11-04-2011, 09:43 PM
Cantankerous Old Redneck
Old OutLaw's Avatar
yes.... i agree it takes usually 50 miles or so to work all the air out
and for all you folks when changing any o-rings....use Vaseline Petroleum Jelly on the orings, and on the chamfer in whatever you're putting them back in...it works better than engine oil and won't damage anything....the best way is to goop the orings first with the vaseline, then put them on the valve-whatever. they won't "roll" thatway......
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, 3/8" cooling lines, Tru-Cool Max, PML, Bumper Mod, Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".....
Old OutLaw is offline
Human Verification
