96 obs has abs light on, why? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-19-2010, 03:23 AM Thread Starter
My 96 Ford f250 has a abs brake light on, when I start it. Shorty after starting the truck it turns off and with in a 5-10 sec it turns back on and stays on. The brake are working fine and have had no brake work done with in last year. Has any see this before or have any sugestions what it could be. Thanks Monte
"STAY TO THE RIGHT AND GAS IT"
montster is offline
post #2 of 10 (permalink) Old 09-19-2010, 05:55 AM
Patrick Feeley's Avatar
Re: 96 obs has abs light on, why?
When mine did that it was the Vehicle Speed Sensor (VSS) in the rear end pumpkin (even though my speedometer was still functioning normally). I could be something else too (such as wiring harness problems). Cheers!
Patrick Feeley is offline
post #3 of 10 (permalink) Old 09-19-2010, 01:00 PM
Fixing Broken Stuff
toolmangary's Avatar
When you turn your key on the lights light up to show you that they work, when you start and drive a vehicle with ABS or RWAL it does a self test every time and if it fails then it turns on the light. You can pull a code and see why it is turning on the light when the light is on, usually the dump valve on the frame in the rear brake line is bad, could be VSS on the rear axle. You really need to pull the code or you are just guessing.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 10 (permalink) Old 09-19-2010, 01:53 PM
Olde gear jammer
johnday's Avatar
Location: Barton City Mi, under a rock or a log, where the skies are sometimes cloudy all day.
Mine is an SD, but maybe I could give a suggestion. Do you have any squeaking from either front corner when turning? I do, and got playing around with my left front sensor, wiggled it around a couple times, and the squeak got worse. And yes, my ABS light is in solid. I had that wheel bearing changed out, and new brakes done around 3k ago, so naturally I suspected that corner.
Question, if your VSS on the rear axle is bad, wouldn't the speedo and cruise both be inoperable?
Another nonaligned spokesperson.
Good stuff, trucks bring it!
I don't care if my thread goes off topic, it's all BS anyway!!!
johnday is offline
post #5 of 10 (permalink) Old 09-19-2010, 04:23 PM
biggreen96's Avatar
check your fluid level also . if comes on when the level gets to low. or it could possible be your vaccum pump starting to go bad.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #6 of 10 (permalink) Old 09-20-2010, 02:44 AM
The "red" Brake warning light will illuminate when the vacuum is low or if the fluid level is low. The "ABS" light is a different indicator. Cheers!
post #7 of 10 (permalink) Old 09-21-2010, 12:13 AM
From the LAND DOWNUNDER
aussie powerstroke's Avatar
Have you replaced any lights or bulbs with LED recently? This will cause the problems you talking about. There is not enough resistance with LED's to current. If you have a simple inline resistor from any good auto shop will solve problem
2005 (Aussie)
7.3 6spd
straight piped, moded air intake,
Driven Diesel reg return system & bowl delete, CAT filters,
Autometer, HPOP, Fuel Pressure, Boost,Pyro
Southbend clutch (stock couldn't handle power )
Tunes by Tony Wildman:thumbsup:.
aussie powerstroke is offline
post #8 of 10 (permalink) Old 09-23-2010, 03:40 AM
Smart A$$
MN_MountainMan's Avatar
Once my ABS light came on and stayed on. Fuse kept blowing. Couldn't figure it out until I fixed the wire that went to the third brake light for the topper. Fixed the wire, replaced the fuse, ABS light went out. Go figure!
Dang ABS don't work anyhow.
'97 F-350 CC 5-spd, Pyro, fuel and boost gauges, Banks intercooler, H2E turbo, Adrenaline HPOP, huge clutch, custom ADII regulated fuel system. Should be about 500 hp at the rear, don't know about torque. THIS IS MY BATTLE TANK- Project in Process
4XMayhem.com
MN_MountainMan is offline
post #9 of 10 (permalink) Old 03-09-2016, 03:50 AM
I PUT A NEW VSS SENSOR ON MY TRUCK. MY ABS SENSOR IS NOW ON. WHEN I TURN THE KEY TO THE ON POSITION THE ABS LIGHT GOES ON AND GOES OFF. WHEN I START THE TRUCK THE ABS LIGHT GOES OFF FOR 2 SECONDS THEN STAYS ON. NAPA TOLD ME THAT THE ABS WILL EVENTUALLY GO OFF FROM CYCLING THE THE TRUCK ON AND OFF. DOES THE 1996 4WD F250 HAVE FRONT WHEEL SENSORS OR JUST THE VSS IN THE REAR DIFF?
Egster55 is offline
post #10 of 10 (permalink) Old 03-09-2016, 10:00 AM
Terminator Nation
RABS= Rear Anti-lock Brake System. Nothing for the fronts.
old man dave is offline
Human Verification
