1997 runs rough then dies!??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 08-16-2010, 01:46 AM Thread Starter
1997F350powerstroke's Avatar
Alright, on my trip back from camping my truck started to shutter and then slowly died, couldnt get it to start, so i got towed home. I put a new fuel filter in it and still nothing, put a cps in it and she started up but ran rough until i floored her and it clered right up, but now the truck acts funny, oh i have a dp tuner on ther truck, anyway the truck starts and drives fine untill like 2500 rpms then it jus has no power beyond 2500, im thinkin injectors maybe? any help would be really great, thanks in advance
97 F250 PS, 4x4 5speed,3"dp, straight piped to 5' dual tip side pipe, homemade tymar,hypermax pushrods,ccv delete,gauges,dp tuner,d60,Heim joint clutch fix,WF2077 coolant filter, LF9691 oil filter, 08 diff cover, In progress electric fuel, warn winch
99 Ford Explorer 5.0 eddie bauer wifes ride
1997F350powerstroke is offline
post #2 of 23 (permalink) Old 08-16-2010, 02:07 AM
Re: 1997 runs rough then dies!???
When you changed the fuel filter did you happen to clean out the screen to the fpr?
02 f250
countryboyrob is offline
post #3 of 23 (permalink) Old 08-16-2010, 02:10 AM Thread Starter
um i hate to say this but what screen? and where is it?
post #4 of 23 (permalink) Old 08-16-2010, 02:14 AM Thread Starter
There was some nasty looking stuff dumping out of the filter, when i changed it
post #5 of 23 (permalink) Old 08-17-2010, 01:22 AM Thread Starter
alright, i found the screen and cleaned it, it was rather nasty, it runs alot better, but my chip, when its in the 80 and above settings makes my truck like chug when i get on it, whats that about? is that because i don't have elec. fuel yet?
post #6 of 23 (permalink) Old 08-17-2010, 01:58 AM
No that shouldnt be the problem.
02 f250
post #7 of 23 (permalink) Old 08-17-2010, 02:48 AM Thread Starter
what would be causing it?
post #8 of 23 (permalink) Old 08-17-2010, 10:05 PM
Russ's Avatar
what color is the fuel in the filter bowl now? If it has a dark tint to it I would think it's time for injector o-rings. Did you find a tiny pieces of rubber in your filter bowl when you changed it?
Stormtrooper:: 1997 F-350 CC SRW PSD XLT 4X4: Baby Swamps, Wildman, SD Intercooler, CCV Mod, shimmed FPR, BTS, Baldwin air filter,triple pillar pod with Isspro gauges, 4" exh, SD dual tensioner mod, diamond cut headlights, Hadley air horns,
Russ is offline
post #9 of 23 (permalink) Old 08-17-2010, 10:17 PM Thread Starter
no nothing like that
post #10 of 23 (permalink) Old 08-19-2010, 02:39 PM Thread Starter
Alright done alot of driving with the truck and it still seems there is no power over 2000 rpms or 5 psi of boost, theres no cel, could there be a soft code limiting the fuel delivery?? any help would be great, Thanks-josh
Human Verification
