Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 05-16-2017, 03:36 PM Thread Starter
Send a message via MSN to Foundordead
Unhappy Help
Ready to burn it to ground!
1995 Ford 7.3 Super duty
Went to take wife to,work.pulle dout of drive made it 3/4 mile down road truck shut off like i had shut the key off.
This is what i have done so far.
Changed cps with kgo. No
changed icp wkgo. Ng
Removed and cleaned IPr
Checked hpop oil pressure 2600 psi while cranking.
Checked fuel pressure coming out of secondary pump 65 psi.
Bought foxwell code reader checked codes.
The only code is p0606. Which is bad pcm. Took it out and brought it to fprd they checked it found to be bad. Lucky for me was still under warranty got new one.
Installed still,no start.
Ran buzz test on injectors came back al good.
Did live read everything looked goe
Help would be greatly appreciated
Foundordead is offline
post #2 of 22 (permalink) Old 05-16-2017, 04:38 PM
danielzink's Avatar
Re: Help
Something is up...
I've always heard/read (and a quick google search says) HPOP oil pressure while cranking s/b somewhere around 500psi...
1997 F-250 Powerstroke, 4x4, D60, RSK, V&B's, 35" BFG ATA's on 16x10's, 6637 DIY Intake, Beans IDM Mod, 3" DP, 4" single exhaust, Beans E-Fuel, Gutted EBPV & Pedestal, Intercooled, Rosewood 160/80's, Brute 66 Turbo, Irate 3" Plenums, Terminator T500, Tony Wildman Tunes, Gauges (Pyro/Boost/Trans).
danielzink is offline
post #3 of 22 (permalink) Old 05-16-2017, 04:49 PM
Diabolic1's Avatar
Re: Help
Yeah, I don't think you should see 2600 while cranking..????
1997 CCSB, 7.3/E4OD
Full Force Stg 1 injectors, 3" DP, 4" exhaust, E-Fuel, 7.3 Intercooler, WW2, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #4 of 22 (permalink) Old 05-17-2017, 11:34 AM Thread Starter
Re: Help
Thanks dead headed the hpop pump found 0 lbs by gauge last night from the drivers side supply line to the head. Ordering a ipr today have it by saturday. Hopefully its not the pump.
The high pressure reading was thru the code reader live setting. Did old fashioned gauge test and that is what i found with icp plugged and unplugged.
post #5 of 22 (permalink) Old 05-17-2017, 12:03 PM
Moderator
Sbluke55's Avatar
Re: Help
2600 psi isn't bad while cranking. It just mean it's building up and not starting. You will get these pressures if it doesn't start.
With only seeing 0 psi is weird. You should see some pressure. I personally don't think it's the ipr.
My vote is the pump. But is the hpop reservoir full?
01 f-250, Standard
Sbluke55 is offline
post #6 of 22 (permalink) Old 05-17-2017, 03:46 PM Thread Starter
Re: Help
Yes it is full to 1/2 in from the top
post #7 of 22 (permalink) Old 05-17-2017, 04:20 PM
Lt.Dan's Avatar
Re: Help
Showing 2600psi from the computer and 0 from mechanical gauge means either the icp is bad or the mechanical gauge is broken. My bet would be the icp. Now since the mechanical gauge is showing 0, it means a hpop is not making any pressure. Even if the ipr was wide open, it should still build around 150-200psi. Check the gear bolt that's inside the front cover, behind the inspection plate, above the water pump, and see if it backed out.
If it is one of those 1 in a million things, that the pump actually failed and isn't building any pressure (which seriously almost never happens), then a factory replacement pump is about $600 online, or a t500 pump for $500. You might also be able to send it to terminator and they can test it to see what's going on with it.
1996 California F350 SRW CCLB, 7.3 Powerstroke, 2wd w/ 354,400 miles, rebuilt at 352,250.
FUGA E-Fuel, T500 HPOP, 3" Diamond Eye DP w/ 4" Straight Pipe, PHP Hydra w/ Swamps Tunes, RiffRaff Bellowed Up-Pipes,
K&N Intake, EBPV delete, High Flow Turbo Outlet, RiffRaff 4/4 Wheel w/ 360* Rebuild, GlowShift Gauges.
Lt.Dan is offline
post #8 of 22 (permalink) Old 05-17-2017, 04:52 PM Thread Starter
Re: Help
Ok will check that out when i get home from work. Thanks for the advice will let you know what i find. With the luck iI have been having lately I will be the one i a million😃
post #9 of 22 (permalink) Old 05-17-2017, 09:14 PM
Lt.Dan's Avatar
Re: Help
Have you tried pulling the plug on the icp and trying to start it? Could eliminate that as a possibility
Lt.Dan is offline
post #10 of 22 (permalink) Old 05-17-2017, 10:42 PM Thread Starter
Re: Help
Changed the ipr out getting pressure now. Shot streak of oil across the yard. Still wont start. To a rag with a little gas on it to see if it would fire. It back fired caught rag on fire. Is it possible that it broke a timing gear or sheared a bolt on cam gear.
Human Verification
