Question on transfer case/zf 5 fluid change - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-13-2017, 03:01 PM Thread Starter
I have searched but cannot find answer. I have a 1997 f 250 with the zf5 and a borg warner transfer case. This truck is new to me, and I am working my way around resetting all fluids. After I drained the T case I expected to fill with 2qts as suggested, but it ended up taking 3qts. Granted I live in the dirt and I picked the flattest place I could, usually where I do most my truck maintenance. It's fairly flat.
Is there a seal between the t case and ZF 5 that can leak and cause fluid exchange between the two? I checked the tranny fluid before I did the T case and fluid started coming out the fill hole, I disregarded this until the T case took three quarts. Now I am wondering.
Also, I used Mobil 1 ATF syn to fill the t case. Am wanting to use Transynd for the tranny. Unless they are swapping fluid, then I guess it will be Mobil 1 in both until I can get to fixing the seal
Workman is offline
post #2 of 12 (permalink) Old 05-13-2017, 03:35 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Question on transfer case/zf 5 fluid change
No, the transfer case is an individual sealed unit. The seals can leak though. Fluid coming out the fill hole is good, that means it has the proper amount in it. (should just be a small stream down the side of the trans, if its dumping out then it was overfilled). I personally, would highly recommend using Motorcraft atf instead, just out of principle alone.
Shoulda bought a Cummins. May or may not have a cummins swap in the works.
1997 7.3L XLT, 4x4, 5spd, 307k, TS chip, 6637 filter, 4" straight piped dual exit
If you got a D60 or tan superduty/OBS seats PM me.
Cummins Junkie is offline
post #3 of 12 (permalink) Old 05-13-2017, 04:51 PM
79jasper's Avatar
Personally I stick to what ford recommends.
The trans can leak into the tcase, but not the other way around. You would have to have the rear end about four foot higher than the front.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #4 of 12 (permalink) Old 05-13-2017, 06:54 PM
alleged moderator
tjctransport's Avatar
i agree with the above. motorcraft ATF only in both trans and t-case.
tom
tjctransport is offline
post #5 of 12 (permalink) Old 05-13-2017, 09:21 PM
Neither unit can possibly leak into the other. There's a spacer between them, and both have shaft seals. If either one leaks, it leaks into the spacer. The fluid can't go from the spacer into either case.
And unless that Motorcraft ATF is synthetic, it should NOT be used in the tranny, since ZF requires synthetic.
madpogue is offline
post #6 of 12 (permalink) Old 05-13-2017, 09:36 PM Thread Starter
Thanks for the intel, staring to just wonder how I got three quarts in the t case. I will check it when I get to level ground and see if how much comes out with fill plug removed and call it good.
Yeah, the side of the zf 5 I have has a label on it that states only synthetic fluid should be used. And I did some digging and I believe that Castrol Transynd is what actually came in the tranny. ZF says to use it as well, and they made the tranny.
Workman is offline
post #7 of 12 (permalink) Old 05-13-2017, 10:04 PM
410customs's Avatar
Mercon V is full synthetic
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liters there is no replacement for displacement!!
410customs is offline
post #8 of 12 (permalink) Old 05-14-2017, 12:38 AM
That rings a bell. And of course, Borg-Warner made the t-case. So I'm not sure why the push. Motorcraft lubes for components not made by Ford.
And it's for sure an F250, right? Original t-case? I ask because the t-cases in the F350s had a different outer case, with a plate for a PTO, and a second, higher fill plug in the front. You use this fill plug to put more fluid in it to use the PTO. But just to be sure, your case only has the one fill plug on the back?
madpogue is offline
post #9 of 12 (permalink) Old 05-14-2017, 02:00 AM Thread Starter
It is in a 97 f 250, and it's the original t case. One plug on the back says drain, and the other fill. Pretty idiot proof.
I parked it on level ground today, pulled fill plug, and nothing came out. Level is up to the top of hole. Guess it takes three quarts!
Workman is offline
post #10 of 12 (permalink) Old 05-18-2017, 03:41 PM
For the ZF 5 I use Redline MTF excellent product especially if higher mileage, iirc I put in 4 litres.
Cheers,
j
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, SRK, SD springs front/rear, 145 litre rear tank (now ZF-5
White / Silver 96 F250 4x2, SCSB E4OD, 4:10 stock for now mods to install: D60, engine stuff.
White VW '15 Jetta 6MT Sport Suspension TDi
JCart is offline
Human Verification
