No Start issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 52 (permalink) Old 05-02-2017, 03:51 AM Thread Starter
tractorman1215's Avatar
No Start issue
Good Evening everyone,
So I have been trying to figure out a No start issue since last September Originally the truck started funny ran and then stalled, the next day It did the same thing started funny stalled but I finally got it running and idling okay. I took it to a fair where it was about 30 degrees outside, this is when the truck started then stalled and wouldn't start again. The next day I tried starting it finally got it running again then I parked it and it hasn't run since. I thought I had it figured out when I found dry rotted fuel lines connecting the bowl and the pump. I also noticed a small fuel leak dripping onto the ground. SO I decided to put myself in debt and bought a Driven Diesel Full Electronic Fuel Conversion kit with Fuel Bowl delete and regulated return & high flow banjo bolts ( I will attach a link). I also did a K38R turbo with a EBPV delete pedestal while I had everything apart. Anyway I finally got everything back together and still just a crank no start condition. The fuel pressure gauge on the fuel regulator is set to 65psi and holds strong at 65. I noticed that no smoke is coming out of the tail pipe while cranking and that the truck isn't even attempting to start. I could just be jumping the gun and the truck could be air bound from the conversion and the dry rotted lines, but is there any other possible issues? My crank sensor is new, batteries are new, put a fresh 15qts of oil in her, don't know if it matters but a new alternator, and then the modifications I mentioned earlier. If you have any suggestions let me know. Could it possibly be the HPOP, ICP, IPR, just looking for some guidance.
Thanks again guys.
Just so you guys know my OBD2 doesn't work so if anything involves a scan tool unfortunately I can't do it as of now.
https://www.strictlydiesel.com/p-343...el-system.aspx
1996 F250 7.3 92k
4 inch lift 37's Goodyear mt military oz
Dana 60 king pin front axle conversion.
Riff Raff HPX Pipe.
Diamond eye 3inch down pipe, 5inch exhaust.
S&B Cold Air Intake
Hydra Chip
Driven Diesel Efuel kit
KC38R turbo
EBPV delete pedestal & output
Up and Coming
Intercooler
Rosewood Injectors
Rust and Rot
tractorman1215 is offline
post #2 of 52 (permalink) Old 05-02-2017, 11:47 AM
c-case7.3's Avatar
Re: No Start issue
I'm having the same problem It hasn't done it in months until this morning when I got up to goto work I've had a leak at the fuel bowl but I can usually get it to start and just hold the throttle at 1k until I feel it idle on it's own
c-case7.3 is offline
post #3 of 52 (permalink) Old 05-02-2017, 08:51 PM Thread Starter
Alright today I tried unplugging the ICP and no difference. I also noticed that my tachometer moves while cranking as well as my oil pressure gauge moved to normal pressure while cranking, which leads me to believe I have good Low oil pressure. Still no smoke out the tail pipe though. Any suggestions are greatly appreciated.
post #4 of 52 (permalink) Old 05-02-2017, 09:05 PM
Moderator
Sbluke55's Avatar
Re: No Start issue
So why doesn't your obd2 work? What year is the truck?
Next thing to do is to check fuses. Maybe rig up a gauge to check you high pressure oil pressure.
01 f-250, Standard
Sbluke55 is offline
post #5 of 52 (permalink) Old 05-02-2017, 09:11 PM Thread Starter
I honestly couldn't tell you why, I've looked into checked fuses for it all of the wiring seems intact. I plug it in and the scanner seems to operate normally until I get an error code about a protocol not being passed. I've tried like 4 scanners as well, anything from craftsman to a genysis. How would I rig up a gauge for the HPOP, and do you think it's ICP or IPR I've been doing some research those seem to cause issues. The truck is a 1996.
post #6 of 52 (permalink) Old 05-02-2017, 11:02 PM
Bugman's Avatar
Re: No Start issue
The vast majority of code scanners out there can not read Fords codes.
So unless it says that they can read the codes from a Ford diesel truck I'd find one that does.
Bugman is offline
post #7 of 52 (permalink) Old 05-02-2017, 11:18 PM Thread Starter
Okay I will look into that. I'm more concerned about the no start issue. I just mentioned the OBD2 so guys would know. Any suggestions on the crank no start issue?
post #8 of 52 (permalink) Old 05-03-2017, 12:45 AM Thread Starter
Update, sprayed starting fluid in the intake and the truck fired up for a split second then died. Hope this helps.
Yes I know not suppose to do that and I'm not going to ever again, just wanted to test a theory.
post #9 of 52 (permalink) Old 05-03-2017, 01:44 AM
Re: No Start issue
You didn't replace the crank sensor; there isn't one. If you replaced the cam sensor, and didn't get it from Ford or International, replace it again. Even if you see a tach signal, that only means the CPS picks up the "heartbeat", not the specific irregular signal that tells the PCM the actual cam position.
Beyond that, you're pretty much at the point where you need a scanner / data read device. You'll want to do a buzz test, and monitor ICP and IPR duty cycle while cranking.
And it's not Ford codes/data that most scanners don't read, it's specifically the protocol used by the OBS PSDs. Other Fords of the era are standard OBD-II. We're just... er... special.
madpogue is offline
post #10 of 52 (permalink) Old 05-03-2017, 02:05 AM Thread Starter
Re: No Start issue
I will definitely do that. Thank you for the help and any particular scanner you know of that works on the OBS PSD.
Human Verification
