how much antifreeze to add??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-07-2010, 02:51 AM Thread Starter
I helped make ur rimz....
MadMax'97PSD's Avatar
alright guys got another question.
I'm planning on changing the antifreeze tomorrow, but I'm not sure how much of the mix i need. when i purchased my dually i didn't get a owners manual so I'm not sure how much antifreeze( and water) i need to add after i do a flush on the system. so does anyone know how much antifreeze do i need to add to my '95 f-350 7.3, I've googled it and didn't come up with anything conclusive, i looked on the ford website and their online manuals only go back to '96. thanks ya'll.
'95 F-350 Crew Cab Dually 7.3L. 187k miles - 6637, bitchin aftermarket headlights
'97 F-250 extended cab 7.3L 216k miles-6637, 4in straightpipe
'99 Dodge 2500 Laramie SLT 5.9L 222k miles- flex pipe exhaust, fatal 53 block- fml.
'92 F-350 CCLB 4x4 7.3IDI
Diesel- Fuel 4 Life
MadMax'97PSD is offline
post #2 of 8 (permalink) Old 02-07-2010, 03:32 AM
Super Hauler!
Super_Hauler's Avatar
Re: how much antifreeze to add???
the are all the same, 1994-1997 then it jumps up a half a gallon in the 99-2003
Super_Hauler is offline
post #3 of 8 (permalink) Old 02-07-2010, 03:48 AM Thread Starter
awesome, thanks powerstrokinc
Diesel- Fuel 4 Life
post #4 of 8 (permalink) Old 02-07-2010, 03:58 AM Thread Starter
hold on i forgot to ask, how much mix do i need gallons wise? the manuals i downloaded only showed half the page, so i cant really tell how much i need to mix
Diesel- Fuel 4 Life
post #5 of 8 (permalink) Old 02-07-2010, 04:13 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
I think it holds about 17 quarts, so 2 - 2-1/2 gallons of AF.
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #6 of 8 (permalink) Old 02-07-2010, 05:15 AM
my trucks used 21-22 quarts
1995 Ford F250 4X4 Sup cab Long bed off white
7.3L Powerstroke, 5 speed manual
Mods Stancor GPR, Diamond eye 3" DP, Diamond Eye 4" Exhaust, AFE Stage II,
Banks 5" Tips,Dana 60 Swap,Electric Fuel System,Swamps IDM,Adrenaline HPOP,AutoMeter Boost,Pyro,Fuel Pressure arp head and main studs,d66 turbo,
stage 1 injectors,6.0 intercooler
Rantheman is offline
post #7 of 8 (permalink) Old 02-07-2010, 05:53 AM
I'd get, at a minimum, 3 gallons of concentrate. When I flushed mine a few weeks ago, I bought 4 just to be on the safe side. I also got 20 gallons of distilled water for flushing/refilling but only ended up using about 15 gallons. Don't forget the FW-16/DCA-4 additive. If I remember right, 4 pints should get you the level you need.
Cheers from Claremore, OK!
Dave
DaveBey is offline
post #8 of 8 (permalink) Old 02-07-2010, 06:07 AM
Terminator Nation
Coolant capacity of the system is 32 quarts. So you would need 16 quarts of antifreeze and 3.5 to 4 pints of Motorcraft FW-16 (or is it 15?). You also can get the additive from IH, called DCA-4 in pint bottles or as I recall, DCA-64 in half gallon bottles. You can get coolant test strips from IH to check the additive level.
When you do a drain down of the coolant system using the radiator petcock, there is a considerable amount of old coolant retained in the block unless you remove the drain plugs on each side of the block. Doing it this way drains out all of the old coolant. Refilling will take 32 quarts of 50/50 coolant and additive.
I do a complete flush of the block/heater with fresh water using a Prestone radiator flushing kit. Drain down the radiator of water, add the DCA-4, add straight anti-freeze to the radiator (about 3.5 gallons) and the rest of the antifreeze into the degas bottle. This will mix over time and also result in a 50/50 coolant mix with additive.
You also can drain down the radiator, refill with water and run the engine. Repeating this process about 4 times results in a pretty fair flush of all the old coolant. Drain down the radiator and refill with coolant/additive the same way as doing the engine flush.
old man dave is offline
Human Verification
