White/blue smoke after injector change - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-31-2017, 05:27 PM Thread Starter
97stockstroker's Avatar
97 7.3 175k miles replaced injectors after #1 &#3 injectors were stuck open runs a lilsmoother but still has a lil white smoke and smells like Diesel I'm stumped on what it could be any info would help.
She loves my powerstroke.
97stockstroker is offline
post #2 of 4 (permalink) Old 03-31-2017, 07:08 PM
410customs's Avatar
Re: White/blue smoke after injector change
how far have you driven it?
Do you feel you seated the injectors fully and without pinching any O rings?
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
SEVEN POINT THREE LEAKER
410customs is offline
post #3 of 4 (permalink) Old 04-01-2017, 12:12 AM Thread Starter
Ive driven it about 10 miles so far. As for seating the injectors I tapped them in with a rubber mallet and then used the lower bolt to pull rest of way then torqued them down.
post #4 of 4 (permalink) Old 04-01-2017, 01:12 PM
410customs's Avatar
Okay so the hold down bolt does not seat the injectors, you seat the injectors the hold down bolt simply holds them there
You need to drive it ALOT more then 10 miles. It needs to be put under load and driven 30-50 miles in order to purge all the potential air pockets from the oil injection system and fuel rails.
Then see if she still smokes.
Blue/grey smoke should clear up 100% when engine is warm
Human Verification
