Pup snacked on my wiring - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-31-2017, 04:26 AM Thread Starter
I have a 97 F250 7.3 5 speed tranny. Got a new puppy that lays under my truck usually and I saw a wire harness hanging down, and when I checked it she had chewed it in two, I have about 12" with 2 wires connected to the reverse light plug, and then hanging from the truck I have a harness with 4 wires. It's hanging down right under the clutch and brake pedal, about 2ft long, from the frame, 4 wires in it, I know two go to the reverse switch on the trans, but can't figure out where the green and green/black wires go, she may have carried part of it away.
batesboy is offline
post #2 of 12 (permalink) Old 03-31-2017, 04:28 AM
heavydoc's Avatar
Re: Pup snacked on my wiring
Neutral start switch?
Sent from my SM-N920V using Tapatalk
heavydoc is offline
post #3 of 12 (permalink) Old 03-31-2017, 02:17 PM
Because I can!!!
Thatchevyguy's Avatar
Neutral start is under the dash. Maybe the wires for the 4x4 light? Pics would help
97 F350 cclb
Lots of go fast parts
Dark candy apple now- twas a 7 different color project truck
5spd swap with SBC
And a 98 Chevy k1500 dd - leveled and looks pretty but is slow as hell!!
OBS FOR LIFE!!!!
Thatchevyguy is offline
post #4 of 12 (permalink) Old 03-31-2017, 02:33 PM Thread Starter
It's 2WD.
batesboy is offline
post #5 of 12 (permalink) Old 03-31-2017, 03:37 PM
heavydoc's Avatar
My bad I thought it was up by the stick shift.
heavydoc is offline
post #6 of 12 (permalink) Old 03-31-2017, 03:39 PM
heavydoc's Avatar
I thought clutch safety switch was under dash.
heavydoc is offline
post #7 of 12 (permalink) Old 03-31-2017, 03:54 PM
79jasper's Avatar
It is. It's on the clutch pedal rod.
The only other 4 wire group in that area I can think of is the rabs2.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #8 of 12 (permalink) Old 03-31-2017, 08:53 PM
Post a pic, as was suggested on the other forum.
madpogue is offline
post #9 of 12 (permalink) Old 04-03-2017, 07:22 PM Thread Starter
Can't I'm new.
batesboy is offline
post #10 of 12 (permalink) Old 04-03-2017, 07:39 PM
Did you try the "Attach" feature?
madpogue is offline
Human Verification
