Whats the difference? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 02-04-2010, 02:48 AM Thread Starter
PSN Newby
strokin95's Avatar
im looking at a 1994 7.3 turbo diesel. whats the difference between it and a powerstroke i dont know alot but the moter looks the same. did they put a turbo diesel in a 94 instead of a powerstroke?
1995 F-250 4x4 exten cab long bed ZF5, 165,000 miles, 4in lift, american racing wheels, maxis 35's, tymar intake, 3' down pipe and 3 1/2 straight pipe 5' tip, 6 postion w/ matts tunes.
strokin95 is offline
post #2 of 30 (permalink) Old 02-04-2010, 02:58 AM
Austinj427's Avatar
Re: Whats the difference?
I think 94.5 was the first year of the psd. Don't quote me on that.
Powerstroke= HEUI, direct injection
non psd= pumped, IDI
Austinj427 is offline
post #3 of 30 (permalink) Old 02-04-2010, 04:00 AM
blageurt's Avatar
The 94 was an IDI with a Turbo put on at the factory. The PSD is totally different. The PSD is HEUI and the 94 and previous are regular injectors...
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #4 of 30 (permalink) Old 02-04-2010, 04:15 AM
pjwoolw's Avatar
The early 94s say Turbo Diesel under the F250 badge. The 94.5s will say Powerstroke. IIRC
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
pjwoolw is offline
post #5 of 30 (permalink) Old 02-04-2010, 04:21 AM
co04cobra's Avatar
the 100% way to tell is look at the vin # all 7.3 powerstrokes heui the 8th number in the vin will be a F
co04cobra is offline
post #6 of 30 (permalink) Old 02-04-2010, 04:42 AM
Terminator Nation
The 7.3 IDI turbodiesel will have the fuel injection pump on top of the engine with external tubes to each injector. The PSD will not.
old man dave is offline
post #7 of 30 (permalink) Old 02-04-2010, 02:56 PM
Mine said turbo diesel on the side and is a powerstroke. It's the first month of production on them.
Vin will tell you what it should be. F is the correct one for a powerstroke.
rrranch is offline
post #8 of 30 (permalink) Old 02-04-2010, 03:02 PM
OBS junkie
Cat_Rebel's Avatar
No, the 94 Powerstrokes just had a badge that said "Turbo Diesel" just like the IDIs. Another thing is that you could only buy a 94 Powerstroke with a 5sp manual. Autos weren't an option then. So if you see a 94 "Powerstroke" with an auto it's really an IDI.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #9 of 30 (permalink) Old 02-05-2010, 01:25 AM
Strokin'
My 94 has a badge that clearly says "Powerstroke" and it is. build date is 05/94. also it is a 5-speed.
the easiest way to find out is check the vin.
3 types is 94:
7.3 IDI (vin M)
7.3 IDI Turbo (vin K)
7.3 DI Turbo (Powerstroke) (vin F)
jakeloney is offline
post #10 of 30 (permalink) Old 02-05-2010, 01:38 AM Thread Starter
PSN Newby
strokin95's Avatar
ok so the truck im looking at is a 94 5 speed that has a badge that says turbo diesel on it. the truck is bout an hour away so i cant look under the hood but he is claiming its a powerstroke. so what im gathering from these posts is get the vin and its a sure fire bet what is it?
Human Verification
