Pulled off the y pipe to install a turbo pressure sensor and noticed it a small film of oil coating the entire inside of the y pipe. The truck has 233k and this was probably the second time if ever being pulled off. Would the reason be because of the ccv being somewhat clogged and if so, how to clean it if possible? Cannot seem to find much at all if it can be cleaned or not. Searches really just pull up the ccv mod.
Thanks.
Thanks.
