Had to floor my truck today while still cold to avoid being hit. As in maybe a few minutes after starting it. Any ways it acted like it wasnt getting fuel and didnt want to go, sputtering. This was around 1500-2k rpm i was able to replicate the problem a couple times until the truck came up to temp then it wouldnt do it again. I check for blow thinking it might be a compression issue but there was none and the truck only has 107xxx miles. Wondering if it was maybe the turbo sticking? I hope its not the fuel pump i just had a new one put on this previous summer. I also doubt its injectors. I for sure have a few bad glow plugs and truck fires up no problem in 0 degrees. I do have a weird intermitent idle issue also truck likes to bounce sometimes and occasionally the tach will jump while doing it. Could this also be a icp/ipr issue or uvch?
