Part Number for Exhaust Back Pressure Sensor/Tube? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-02-2010, 03:11 AM Thread Starter
Tater for President!
I am looking for the part numbers for the Exhaust Back Pressure Sensor and the Tube that comes off of the passenger side exhaust manifold for my '97.
Thanks,
Casey
#31
1997 F-250 - SCSB - ZF-5, 4x4, 4.10, 17* HPOP, Tymar Intake, TWildman Tunes, SD IC, 4" Straight Exhaust, Dana 60 w/ 3.5" RSK and SD Springs all around on 35" BFG A/Ts - SOLD
2009 - 6.4L - Crew Cab/Long Bed - FX4 - 4" Pure Performance X-Factor Lift - 325/60/20 Duratracs -- FOR SALE
2014 - 6.7L - Crew Cab/Long Bed - Lariat 4x4 - Stock
PSDfreak is offline
post #2 of 11 (permalink) Old 02-02-2010, 03:26 AM
cattle farmer
powerstroke742008's Avatar
Re: Part Number for Exhaust Back Pressure Sensor/Tube?
i could not ever find a part number so i caped it off
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
post #3 of 11 (permalink) Old 02-02-2010, 03:41 AM
Don't EFN worry about it
Aljay's Avatar
Mine is gone plugged the manifold. To the OP I have a tube if you need it.
Tuned by T Wildman
Aljay is offline
post #4 of 11 (permalink) Old 02-02-2010, 04:31 AM
Here's what I've got... I think the tube routing changed for the '97 model year though. On my '96 (and prior years) the tube runs from the exhaust manifold, behind the alternator bracket, and up behind the high pressure oil reservoir. I know on the Super Duties, and I think the '97s, the tube runs from the exhaust manifold up the front of the engine and in front of the high pressure oil reservoir. I think the part number below is for the earlier style. I myself am looking to change my truck to the later style.
9J432 BRACKET (TRANDUCER MOUNTING)
MODEL/RESTRICTIONS | ENG. CYL. | PART NO. | DESCRIPTION | QTY.
F250, F350, F(Super Duty)- -DI Turbo | 8 Cyl. 7.3 | F4TZ 9J432-B | Bracket assy-Exhaust Back Pressure(EBP) & engine cover front | 1
9J460 SENSOR ASY. (EGR PRESSURE VALVE)
F250, F350, F(Super Duty)- -DI Turbo | 8 Cyl. 7.3 | F7TZ 9J460-AA | Transducer-exhaust back pressure. Includes seal 1807264-C1. Mounts to 9J432. | 1
9D477 TUBE (EXHAUST GAS RECIRCULATING VALVE TO EXHAUST MANIFOLD)
F250, F350, F(Super Duty)- -DI Turbo | 8 Cyl. 7.3 | F4TZ 9D477-A | Tube-Exhaust Back Pressure Sensor. Uses 9F485 1/4"-18 connector. | 1
Cheers from Claremore, OK!
Dave
DaveBey is offline
post #5 of 11 (permalink) Old 02-02-2010, 06:16 AM
ianjadkins's Avatar
If its plugged have you tried to un-plug it. Mine was plugged so I took the sensor off the top, sprayed a bit of WD40 in to soften the soot, and started to poke throught the soot with some mechanics wire. I ended up working it around the bends and about 2" down and broke through. I did this with the truck running so the exhaust would push the soot out when I broke through. It worked great.
95 Extended cab Long Bed XLT
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
ianjadkins is offline
post #6 of 11 (permalink) Old 02-02-2010, 02:08 PM Thread Starter
I'll give it a whirl
#31
PSDfreak is offline
post #7 of 11 (permalink) Old 02-02-2010, 02:17 PM
Dave
I cleaned my tube and replaced the sensor a couple weeks ago and my tube runs behind the alternator bracket on my 97.
kw900driver is offline
post #8 of 11 (permalink) Old 02-02-2010, 04:59 PM
If you need a replacement, Rockauto has a listing for them, drill down in their catalog to your YM - it's called an EGR tube. Around 20 bucks.
'95 F250 Extended Cab E40D 2WD
IDM MOD - HPX -
dzlstroker is offline
post #9 of 11 (permalink) Old 02-03-2010, 02:58 PM
If your truck was made from March of 97 to the end of 97,the ford part #is F7TZ-90477-AA.
Hope that helps.
1997 F250 XLT CC 4X4 PSD E4OD 4.10LS (AB CALI TRUCK)
INTAKE
18K MOD
4"TURBO BACK DE EXHAUST
1705 SUPERCHIP
2" LEVELING
GAUGES
SONNAX VALVE WITH SPRINGS
TRANS COOLER
SWAMPS IDM
1996 F250 XLT EC 4X4 PSD E4OD 4.10LS
1705 SUPERCHIP
QUAD POD from Complete Performace
BD EXH BRAKE
3" DOWN PIPE
TRANS COOLER
DIY INTAKE
120v IDM
ono_55 is offline
post #10 of 11 (permalink) Old 08-21-2012, 03:13 PM
I'm going to bring this thread back from the dead. I'm looking to switch my tube and sensor from behind the HPOP res to in front like my old 97 that had it in front of the HPOP access cover. Did any of you guys ever do this? Does the plug in the harness reach??
Jamie V is offline
Human Verification
