U-Joints!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 (permalink) Old 02-14-2017, 08:36 PM Thread Starter
CAT lover
U-Joints!!!
Converting my truck to 4x4. The swap is almost complete and I got new (to me) drive shafts. The u-joints were junk so im trying to get some new ones. I want spicer!
Anyone have the spicer PNs for the front and rear U-Joints? 3 on front shaft and 2 on rear shaft. Thanks!!!!
96 F250 RCLB 4x4 7.3
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
Robertl211 is offline
post #2 of 12 (permalink) Old 02-14-2017, 08:56 PM Thread Starter
CAT lover
Re: U-Joints!!!
What im gathering from some research is the normal greasable spicer u-joints are:
front: 5-213x (times 3 of them)
rear: 5-3147x (times 2 of them)
the spicer life u-joints (non greasable) are:
front: 5-790x
rear: 5-795x
Can anyone confirm?
post #3 of 12 (permalink) Old 02-15-2017, 01:44 PM
410customs's Avatar
Re: U-Joints!!!
I hate the games they play with part numbers these days
It used to be U joints were a 10 series a 30 series and a 50 series now they have all these fancy part numbers
Rear driveshaft all 3 same joint:
Spicer 5-178X or 5-1350-1X
at axle, at center support, at transfer case:
Bearing Cap Diameter (In): 1.188 X 1.188 Inch
Greaseable: Yes
Length (In): 3.625 X 3.625 Inch
Snap Ring Type: External
Front Driveshaft, all 3 same U joint:
5-213X or 5-1330-1X
Bearing Cap Diameter (In): 1.062 X 1.062 Inch
Greaseable: Yes
Quantity Per Vehicle: 1
I prefer non greaseable they seem to last alot longer and I'm the type that greases everything each oil change
rear driveshaft uses 1350 series, front driveshaft uses 1330 series
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
SEVEN POINT THREE LEAKER
410customs is offline
post #4 of 12 (permalink) Old 02-15-2017, 04:39 PM
bedliner99
Re: U-Joints!!!
I think Spicer is China nowadays. NEAPCO is made in Pennsylvania and tough to get through a dealer network only. More expensive but brutes in driveline. Get what u pay for. My left front axle joint was NAPA lasted 8k miles. That is when I found NEAPCO.
bedliner99 is offline
post #5 of 12 (permalink) Old 02-16-2017, 02:03 AM
csp
Re: U-Joints!!!
Spicer is NOT China made.
79jasper likes this.
csp is offline
post #6 of 12 (permalink) Old 02-16-2017, 06:11 PM Thread Starter
CAT lover
Re: U-Joints!!!
Thanks guys, after some more research I found for my RCLB F350 4x4 the rear shaft is 5-1204x in the rear, and 5-213x in the front. The front driveshaft is 5-1204x in the front, and 5-213x (x 2) at the t-case
post #7 of 12 (permalink) Old 02-16-2017, 06:27 PM
79jasper's Avatar
Re: U-Joints!!!
Don't buy cheap. You'll regret it.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #8 of 12 (permalink) Old 02-16-2017, 06:39 PM Thread Starter
CAT lover
Re: U-Joints!!!
I bought the spicer u-joints just for that reason, I hear great things about their quality.
post #9 of 12 (permalink) Old 02-16-2017, 08:18 PM
m j
m j's Avatar
Re: U-Joints!!!
The Expert - K350 - Information for driveshafts, u-joints, axles, heavy axles, light axles, Driveline
interactive ujoint selector for Spicers.
when was this 'used to be'?
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #10 of 12 (permalink) Old 02-16-2017, 08:20 PM
79jasper's Avatar
Re: U-Joints!!!
1310, 1330, 1350.
I wanna say the idi Era.
79jasper is offline
Human Verification
