sensors on the factory filter housing 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-31-2010, 09:13 PM Thread Starter
Talking sensors on the factory filter housing 7.3
I am going to do the Electric pump conversion.
My question is what are all the sensors on the OEM filter housing and there location.
I would guess pressure, Water, ???
Any input would be appricated.
Thanks
John
metrojd is offline
post #2 of 6 (permalink) Old 01-31-2010, 09:33 PM
I make smut cry
Re: sensors on the factory filter housing 7.3
Fuel bowl heater, water in fuel light sensor and I think there's one more.... Maybe Im thinking of the EBPV wire....not sure
I deleted my fuel bowl and didn't re-use the sensors. Re-did the harness and it looks factory now.
Powerstroked162 is offline
post #3 of 6 (permalink) Old 01-31-2010, 10:15 PM Thread Starter
I am putting a hobs switch on and figured I could wire that up to the low pressure light [if there is one]
I am doing the OP switch for safety...
Also have a Racor filter/ Water seperator with a water sensor on the bottom, Figured if there is a water sensor on the old housing I would use it also.
Thanks
John
metrojd is offline
post #4 of 6 (permalink) Old 01-31-2010, 10:26 PM
John -- There's the fuel heater, water in fuel lamp, and fuel filter restriction lamp connectors.
The water in fuel sensor is the bottom-most post connector, the fuel heater is the spade-style connector above that, and the fuel filter restriction sensor is the sensor in the fuel pressure regulator block.
Hope that helps!
Cheers from Claremore, OK!
Dave
DaveBey is offline
post #5 of 6 (permalink) Old 01-31-2010, 10:28 PM Thread Starter
Talking Re: sensors on the factory filter housing 7.3
Hope that helps!
Dave
Thanks
That is what I was looking for...
Thanks
John
metrojd is offline
post #6 of 6 (permalink) Old 01-31-2010, 11:47 PM
Michael's Avatar
Hope that helps!
Dave
Just a clarification for those working on a 94.5 or 95 truck, the fuel restriction sensor is in the back of the fuel bowl at the bottom. They moved it to the FPR after that.
Regards,
Michael Pliska
95 F350 CC DRW, ISSPRO Performax gauges, Diamond Eye 3x4" DP & 5" exh, MBRP tip, Baby Swamps & tunes, Trans VB mods, Dunrite TC, Lock-Right, Cal-Tracs
99 Silverado race truck
96 F250 RCLB, bone stock
00 Jetta TDI, Kerma Tunes, Der Chimera Stg 3 clutch
73 & 74 Vega race cars, 92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 Trans-Am 455
Michael is offline
Human Verification
