New to me 1997 F350 7.3 4 door long bed 5 speed 4x4 - Let the buildup begin! HELP!! - Page 11 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 19Likes
post #101 of 292 (permalink) Old 09-22-2016, 04:49 AM
79jasper's Avatar
Re: New to me 1997 F350 7.3 4 door long bed 5 speed 4x4 - Let the buildup begin! HELP!!
Originally Posted by Thatchevyguy View Post
IDIs have different clutches. Is there a chance the cover might be different to??
Probably.
I recall there being a "updated" part with more clearance.
I think madpogue was saying
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #102 of 292 (permalink) Old 09-22-2016, 04:52 AM
Because I can!!!
Thatchevyguy's Avatar
Garage
I suppose that makes sense then
97 F350 cclb
Lots of go fast parts
Dark candy apple now- twas a 7 different color project truck
5spd swap with SBC
And a 98 Cheby k1500 new dd
OBS FOR LIFE!!!!
Thatchevyguy is online now
post #103 of 292 (permalink) Old 09-22-2016, 01:15 PM Thread Starter
Sorry to her your clutch/inspection cover is grinding. It wasn't rubbing on the truck it came off of.........hmmmmm did it get bent in shipping you think? I feel bad it caused you more work.
Dude!! Do not even sweat it! Shes on there and no more rubbing. It literally took 2 minutes with a grinder and a pair of pliers to make it fit.
My truck is a 97 diesel engine with a who knows what year 460 Zf5 trans, so I knew the risks
All I had to do was remove about 1/4" from the oil pan "lip" with a grinder, hit that with the belt sander. Made a notch for where the Napa starter goes and it fits perfectly. I spent more time looking for three bolts and lock washers to use for mounting then I did making it fit. I am headed into the woods later today to get firewood with the F350, so having a guard over that rotating mass is very important to me!!
You did an excellent job packaging that stuff, no it did not get bent I am super happy just to have the part! Otherwise I would be making something from scratch.
I think a good grey used drivers door panel might be the most rare of all the parts! If I can find one of those I can make these panels last for a while, the pass one is cracked but no biggie. Drivers is in about 3 pieces all held on with different screws HAHAHAHAHA
My Bronco II took me 15 years to build into a rattle free late model feature having smooth riding Ford truck. This one should take WAAAAAY less time, so far we are kicking some BUTT!!!
1997 CCLB 7.3, ZF5, 4x4, 4.10, brought back from the dead
2001 Excursion 7.3, auto, 4x4, 3.73, new to us freight train family hauler
I build custom trucks and off road toys in my private shop located in Crawlorado
410customs is offline
post #104 of 292 (permalink) Old 09-25-2016, 02:41 PM Thread Starter
Bad news first:
Still major oil leak???? Not sure if I jacked up putting in the rear plug on the HPOP or if I just actually never fixed the right leak?
Cannot see ANYTHING down in there, what a bitch
Will tear the HPOP and fuel bowl off today = PITA
Good news
I'm a happy dude
picked up a flatbed for the F350 today
Freedom 8.5' long srw contractor style all steel was on a 2012 SRW longbed Ford so it SHOULD bolt on. If it does not I will make it so.
I've been after this flatbed for over two months (craigslist) and when I finally got the $$$ (sold atv) it as still there! So I scored!!!
Exactly like this one, barely used!!
8.5' long 7' wide, PERFECT!!!
post #105 of 292 (permalink) Old 09-28-2016, 01:20 AM Thread Starter
OKay working on my oil leak
Pretty sure I fixed the fuel leak
Valley is dry
I have nice honey brown oil coming down the drivers side back of the engine.
It is coming down from above the oil cooler
It is leaking down the engine to transmission adapter plate, from somewhere on the back side of the drivers head
Also getting some oil on pass side
Could it be my turbo pedestal or EBPV delete I did? Hard to see back there.
Any tips?
Remove drivers inner fender skirt for a better view?
Dang
Thanks for any help
post #106 of 292 (permalink) Old 09-28-2016, 01:44 AM Thread Starter
I think I may have screwed up, Oil leak:
When I deleted my pedestal I did not replace the ebpv solenoid/sensor onto the pedestal
I gutted the plunger and spring from the ebpv actuator
I sealed up the plunger rod hole with a ppipe tap but I did nothing to the solenoid/sensor shaft. Then I did not re install the sensor
Should I have?
Thanks
post #107 of 292 (permalink) Old 09-28-2016, 02:14 AM
79jasper's Avatar
Yes. I put mine back in place. That's a oil port. Lol
79jasper is offline
post #108 of 292 (permalink) Old 09-28-2016, 02:33 AM Thread Starter
oil comes up around that stud? Are you 100%?
Thanks so much
I pulled sensor off and using a mirror and flashlight, its dry as a bone underneath!
I had sensor on the stud, in place, but not bolted down.
All I remember in there is a washer sensor washer and then top nut, no O rings
Remember this 97 is diff sensor then the Superduties
I do not think oil comes through that spot!!
I am thinking its the service plugs on back of the heads?
post #109 of 292 (permalink) Old 09-28-2016, 02:56 AM
Moderator
Sbluke55's Avatar
I would say the oil gallery plug on the back of the head
01 f-250, Standard
Sbluke55 is offline
post #110 of 292 (permalink) Old 09-28-2016, 03:18 AM
79jasper's Avatar
Yeah. That thing works just like the ipr.
I popped the stud out, seen I couldn't plug it. So I put the Solenoid and everything back on to hold it tight.
That's what holds it in.
You could get in there with a inspection mirror.
79jasper is offline
Human Verification
