I have a 1997 Ford F-350 cab and chassis truck. Ran into an issue today taking it to get an alignment, seems to be the radius arm on the passenger side has a slight bend in it is due for replacing. Long story short, looking to either rebuild entire front end or put the money towards a much more functional 4x4 swap. My question is I know the frame is 2" narrower (34" vs 36" normal truck). Looking for a D60 front axle, is the width between the perches different between a normal truck and CnC truck different? Mainly, will a D60 off another F350 OBS have the right width for the perches or will I have to find a CnC 4x4 or cut and re-weld new perches on at correct widths?
Thanks, searched all over and couldn't seem to find much info on axle widths between them all.
-Jeremy
-Jeremy
