I am just curious on all what needs to be done to swap FROM a ZF5 TO an E40D, not the other way around, just so it's clear.
My 94.5's ZF5 is in rough shape, it needs a rebuild. My steering column is also shot and I can find good used auto columns easily, but can't seem to find a floor shift column.
Things I know:
Change gauge cluster
steering column
ditch flywheel for flexplate
driveshaft lengths will need to be addressed
auto PCM
My questions:
Will my transfer case swap over to a 4wd E40D?
Any issues with swapping manual cluster/column for auto cluster/column, meaning all plugs and wiring match?
Trans wiring..... that is the big one. Do I have to get a complete underhood auto/engine harness or could I just make a trans wiring harness and pin it into my factory manual harness where it plugs into the PCM?
I don't like shifting personally, The slow 0-60 acceleration in CA traffic sucks, and I see good used E40D's pop up on CL pretty often, where a good used ZF5 to replace mine comes up rarely and are pricey around here. Combined with the fact I need a new steering column/trans anyway, it's an entertaining thought of being able to drive one handed and not have to run that hand shaker and clutch.
Things I know:
steering column
auto PCM
My questions:
