7.3 to a 460 Big Block swap?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 11-29-2009, 09:06 PM Thread Starter
crittergitters.net
woody_1's Avatar
Hi, its been awhile since I posted.I had some truck issues.I blew the head gasket on my 7.3 .I am afraid if I just replace the gasket and not Fire ring the heads it will happen again. It seems it is going to be pretty expensive for the work on the 7.3 heads.I assume to much boost? I am thinking about selling the motor and going BIG BLOCK for the mud races.Something faster off the line.My question is I have a brand new BTS tranny E4OD with a PCS controller what do I need to change for the big block to still run this tranny? And I will have some parts or whole motor for sale in the near future maybe.It still runs now just builds pressure instantly. Any advise would be helpful.
Woody
1995 F350,AFE stage 2 ,3" Down pipe,4" Magnaflow Exhaust,custom Shackles,14" and 15" Atlas springs,54"Boggers,20"x14"wheels,2 1/2 ton rockwells w/ 6.72 gears,F-550 Disc brakes,High rise steering,Tranny cooler,Shimmed FPR, gutted EBPV.Autometer gauges.BTS tranny with a PCS trans controller,Stage 2 injectors,Tony's Wildman 6 position chip,Pedal mod.
woody_1 is offline
post #2 of 21 (permalink) Old 11-29-2009, 09:09 PM
Davey B
davey99ps's Avatar
Re: 7.3 to a 460 Big Block swap??
The bellhousing is different for 460 then it is for a 7.3
95 CCLB- 238/100s, H2E, termy t500, wipe out pushrods, comp 910s, mbrp exhaust, bdp tunes, and 8" lift
99 ex cab - Rolled 3/10/10
davey99ps is offline
post #3 of 21 (permalink) Old 11-29-2009, 09:15 PM
destroked has adapters if i remember right.
with only stage 2's. i dont see you having a problem with studding the heads and leaving it be
PMRCM#1
slowleak is offline
post #4 of 21 (permalink) Old 11-29-2009, 09:17 PM
Davey B
davey99ps's Avatar
Advanced adapters makes one to i beleive. Like slowleak said though, where your at power wise i would think it would be alot cheaper to stud your engine rather than building and swapping in a big block.
post #5 of 21 (permalink) Old 11-29-2009, 09:46 PM Thread Starter
crittergitters.net
woody_1's Avatar
Thanks,I have had a few bids on just the labor is around $2000.00 Then when they see the truck they back out.
woody_1 is offline
post #6 of 21 (permalink) Old 11-29-2009, 09:48 PM
how many time has it blown a head gasket?
countryboyrob is offline
post #7 of 21 (permalink) Old 11-29-2009, 09:52 PM Thread Starter
crittergitters.net
woody_1's Avatar
First time.
woody_1 is offline
post #8 of 21 (permalink) Old 11-29-2009, 09:53 PM
what turbo are you running?
PMRCM#1
slowleak is offline
post #9 of 21 (permalink) Old 11-29-2009, 09:54 PM Thread Starter
crittergitters.net
woody_1's Avatar
Just stock.
woody_1 is offline
post #10 of 21 (permalink) Old 11-29-2009, 09:56 PM Thread Starter
crittergitters.net
woody_1's Avatar
The last time in the mud ,I looked up and seen the boost gauge 45 .Do not know where it was or if that was the max it hit.
woody_1 is offline
Human Verification
