quick connect fuel lines on 1996 F 250 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-18-2009, 12:07 AM Thread Starter
Bruno2's Avatar
I have a 1996 F - 250 . I think the fuel lines are sucking air and was thinking it was the quick connect fittings have deteriorated o rings . Can these O rings be replaced and if they can where is the best place to get them ? Does anybody have a part # ?
Bruno2 is offline
post #2 of 6 (permalink) Old 11-18-2009, 12:31 AM
The Original
BigStroker's Avatar
Re: quick connect fuel lines on 1996 F 250
What fittings where?
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #3 of 6 (permalink) Old 11-18-2009, 12:34 AM Thread Starter
Bruno2's Avatar
The ones on the fuel lines running from the tanks to the fuel pump , but , not the ones behind the motor .
Bruno2 is offline
post #4 of 6 (permalink) Old 11-18-2009, 03:08 AM Thread Starter
Bruno2's Avatar
nothing , notta , zero , zilch , nathan , (spanish word for nothing), German translation , Nine
Bruno2 is offline
post #5 of 6 (permalink) Old 11-18-2009, 02:17 PM
Non-expert thought - seems like they'd be hard to get out and back in. Have you popped them apart yet and checked for rust on the fittings on the tank? That'd be my first suspect.
madpogue is offline
post #6 of 6 (permalink) Old 11-19-2009, 05:35 AM
Demon Dually
speeddemon31176's Avatar
I can't give you a part number but yes they are replaceable. go to your local parts store and check out the fuel repair section. They have the o-rings and lines etc.. you will have to match them up or maybe one of the guys there can look it up in a book(god forbid they should use one).
speeddemon31176 is offline
Human Verification
