Torque App for OBS Android - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 318 (permalink) Old 01-12-2014, 10:18 PM Thread Starter
m j
m j's Avatar
I think 'we' (more like me as I am polluting their thread with OBS stuff ) may as well split from the Super Duty thread found Torque App for Android
Mode/PID: 221445
Long name: Exhaust Back Pressure 7.3
Short name: EBP
Min value: 0
Max value: 75
Scale: x1
Unit: psi
Equation: (((A*256)+B*0.03625)-6.5
Header: Auto
comments: 12/01/2014
Mode/PID: 22114A
Long name: IATf OBS
Short name: IATf
Min value: 0
Max value: 100
Scale: x1
Unit: f
Equation: (((A*256)+B)*-0.00370)+193.39
Header: C410F1
Mode/PID: 221452
Long name: Boost OBS
Short name: Boost
Min value: 0
Max value: 60
Scale: x1
Unit: psi
Equation: ((((A*256)+B*0.00109)-15.73)-Baro()
Header: C410F1
comments: 12/01/14 seems to read psia
Mode/PID: 221452
Long name: MAP frequency OBS
Short name: MAPf
Min value: 100
Max value: 256
Scale: x1
Unit: Hz
Equation: ((A*256)+B)*0.00395
Header: C410F1
Mode/PID: 22114A
Long name: IAT volt OBS
Short name: IATv
Min value: 0
Max value: 5
Scale: x1
Unit: V
Equation: ((A*256)+B)/11099
Header: C410F1
Mode/PID: 221452
Long name: MAP OBS
Short name: MAP
Min value: 0
Max value: 50
Scale: x1
Unit: psia
Equation: (((A*256)+B)*0.00109)-15.73
Header: C410F1
Mode/PID: 221452
Long name: MAP kpa OBS
Short name: MAP
Min value: 0
Max value: 1000
Scale: x1
Unit: kpa
Equation: (((A*256)+B)*0.00752)-109.25
Header: C410F1
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #2 of 318 (permalink) Old 01-13-2014, 12:28 AM Thread Starter
m j
m j's Avatar
Re: Torque App for OBS Android
Mode/PID: 221445
Short name: EBP
Min value: 0
Max value: 75
Scale: x1
Unit: psi
Header: Auto
Mode/PID: 22114A
Long name: IATf OBS
Short name: IATf
Min value: 0
Max value: 100
Scale: x1
Unit: f
Header: C410F1
Mode/PID: 221452
Short name: Boost
Min value: 0
Max value: 60
Scale: x1
Unit: psi
Header: C410F1
Mode/PID: 221452
Short name: MAPf
Min value: 100
Max value: 256
Scale: x1
Unit: Hz
Header: C410F1
Mode/PID: 22114A
Short name: IATv
Min value: 0
Max value: 5
Scale: x1
Unit: V
Header: C410F1
Mode/PID: 221452
Long name: MAP OBS
Short name: MAP
Min value: 0
Max value: 50
Scale: x1
Unit: psia
Header: C410F1
Mode/PID: 221452
Short name: MAP
Min value: 0
Max value: 1000
Scale: x1
Unit: kpa
Header: C410F1
Mode/PID: 221127
Long name: Baro1 OBS
Short name: Baro27
Min value: 0
Max value: 20
Scale: x1
Unit: psia
Equation: A*0.1
Header: C410F1
Mode/PID: 221442
Long name: Baro2 OBS
Short name: Baro42
Min value: 0
Max value: 20
Scale: x1
Unit: psia
Equation: ((A*256)+B)/4.01463133)*0.145038
Header: C410F1
Mode/PID: 221442
Long name: Baro kpa OBS
Short name: Baro
Min value: 0
Max value: 100
Scale: x1
Unit: kpa
Header: C410F1
Mode/PID: 221442
Long name: Baro inH2O OBS
Short name: Baro
Min value: 0
Max value: 100
Scale: x1
Unit: inH2O
Equation: (A*256)+B
Header: C410F1
m j is offline
post #3 of 318 (permalink) Old 01-13-2014, 12:44 AM Thread Starter
m j
m j's Avatar
Mode/PID: 2211BD
Long name: TFT V OBS
Short name: TFT V
Min value: 0
Max value: 5
Scale: x1
Unit: V
Header: C410F1
comments: 12/01/2014 untested
m j is offline
post #4 of 318 (permalink) Old 01-13-2014, 01:19 AM
plzstrokeme's Avatar
Thanks man. Im confused but working it out. This app is awsome. Should have my blue tooth adapter this week and can start logging info.
Old Blue, 97' F350, CCLB, 7.3, Auto,
Air: HiFlo Filter, 3" dp 4" out, SD IC, 3 Inch Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
plzstrokeme is offline
post #5 of 318 (permalink) Old 01-13-2014, 02:50 AM
Glad to see all the work going into this to allow torque to work with an OBS. Subscribed.
greenwhite1 is offline
post #6 of 318 (permalink) Old 01-13-2014, 02:49 PM
csp
I'm assuming that all of that data is what you use to program the app for measuring certain parameters?
For those of us who haven't used it or haven't even seen it, throw us a bone what all of that is.
csp is offline
post #7 of 318 (permalink) Old 01-13-2014, 03:08 PM
It is an app that allows you to monitor what the computer already sees in our trucks via the sensors. If you buy a Bluetooth obd11 plug (I have had good luck with the one from newegg.com less than $20.00) and the torque app (around $7.00) it saves hundreds on external gauges.
post #8 of 318 (permalink) Old 01-13-2014, 03:41 PM
96powerstroker's Avatar
Hmm I might have to look into this . Just wanting to hear if they prove accurate & where u guys have ur phones mounted so u can see them
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #9 of 318 (permalink) Old 01-13-2014, 05:39 PM
csp
Understood what the app does. My question is about all of the data in the first two posts of this thread.
Thatchevyguy likes this.
csp is offline
post #10 of 318 (permalink) Old 01-13-2014, 06:14 PM
The free version allows you to read codes on newer vehicles. You will need to buy the pro version to be able to monitor our trucks. Once you install the purchased version you will need to add the "power stroke pids" but the OBS 7.3 is limited in what it monitors with those pids. There has been some guys figuring out the formulas on a different forum for OBS 7.3 and the info in the first post is what you will need to add custom pids for our trucks as the app doesn't have them in the "power stroke pids"
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/17-1994-1997-power-stroke-technical-info/299202-torque-app-obs-android.html
Posted By For Type Date
Is my truck OBD1 or OBD2? - Ford Powerstroke Diesel Forum This thread Pingback 02-19-2016 02:28 AM
97 F350 poawerstroke + Torque Pro = nodda - Ford Powerstroke Diesel Forum This thread Pingback 12-17-2015 01:33 AM
Wireless Scan Tool - Ford Powerstroke Diesel Forum This thread Refback 11-30-2015 05:19 AM
Android app? / Diagnostics? / mechanical temp gauge? - Ford Powerstroke Diesel Forum This thread Pingback 11-21-2015 12:03 AM
Android app? / Diagnostics? / mechanical temp gauge? - Diesel Forum - TheDieselStop.com This thread Pingback 11-20-2015 11:44 PM
